Fans NOT working at all & Lighter
Old Aug 19, 2013 | 08:45 AM
Tremendus's Avatar
Default Fans NOT working at all & Lighter
Hello Everyone, this is my first post here.
I have a 1994 Honda Accord Ex I recently bought. I can't seem to figure out why the Fans are not working at all. I notice that the fans do not come on when I switch on the Fan and or AC. I get nothing blowing at all. The lil indicating lights work and so does the radio and dome light.
I have also noticed that the lighter is not working.
I have checked all fuses and are all good.
Let me know what you think, Thank you.
Old Aug 19, 2013 | 10:44 AM
mrj_accord's Avatar
Default Re: Fans NOT working at all & Lighter
check the relays in the fuse box under the hood on the passenger side. if u have a friend that has the same model accord as use, borrow his and try to see if they work. if the fans dont kick in then you could have a wiring issue ormaybe ur fan motors are shot!
Old Aug 19, 2013 | 12:09 PM
Tremendus's Avatar
mrj_accord thanks for your response.
I will check the relay under the hood. Do you think it might be the blower motor relay as well??? (under the dash?)
Old Aug 19, 2013 | 02:01 PM
mrj_accord's Avatar
the fans should kick in especially if ur using ur AC.
when u turn on ur heat/ac do u get air from the vents?
sometimes the motor gets clogged with dust, dirt, etc. so if u have no air coming out of the vents u might have to check it first. if it still doesnt spin then the motor is probably shot.
Old Aug 19, 2013 | 02:53 PM
Tremendus's Avatar
mrj,
Yeah, when I turn on the fan or a/c there is no air whatsoever that comes out, it doesnt matter how high I turn it up. The fan doesn't come on either.
Ive been researching this for some time today, some say it's the motor other say it can be the resistor or relay......sometimes even the switch.
Old Aug 19, 2013 | 05:35 PM
mrj_accord's Avatar
take out ur blower motor and run wires into the clip and give it a light tap on the battery. see if it spins. no spin then u know that blower motor is shot. if it does spin then i would check relays and fuses before u start tearing into wires and looking for a short.
Old Aug 20, 2013 | 07:44 AM
Tremendus's Avatar
mrj,
Thanks for your help man, I will definitely check those things out. Will get back with results.
Old Aug 20, 2013 | 09:15 AM
professorman's Avatar
+1. Test the fan motor directly. Mi crapped out 2 years ago.
doogylove69
Jun 26, 2018 06:48 PM
MG17
Honda Accord (2013 - 2015)
Jun 21, 2017 05:01 PM
Dffdixie
Honda Civic (2001 - 2005)
Oct 26, 2016 01:52 PM
Xjbw1983
Aug 30, 2016 01:49 PM
pendejon
11
Aug 20, 2005 01:06 PM
