b16a header fitment issue
Old Aug 18, 2013 | 05:07 PM
myefhasaname's Avatar
Default b16a header fitment issue
I have a 1991 Honda civic DX hatchback with a swapped b16a from an sir-II sitting on has port mounts. I went out and picked up some of the vibrant 4-2-1 headers to use to increase the diameter of my exhaust to 2.5 inches. The vibrant header is one piece and I could not fit it in from the bottom between the engine block and the subframe brace so I was going to try from the top. Needless to say after removing everything off the front of the car, taking 2 of 3 motor mount out and lifting the engine a bit and even grinding down the subframe brace down as much as I was comfortable doing still no luck. I got the headed to seat in the bolts but could not lower the block without crushing the headers between the headers and the subframe. Unfortunately I'm 1000$ dollars into this upgrade with the BWR test pipe, the buddy club spec 2, and the headers. Can someone please help?
Old Aug 18, 2013 | 05:26 PM
crvtectim's Avatar
Default Re: b16a header fitment issue
If you're not comfortable hacking up the crossmember anymore, then it's time to start shopping for a quality traction bar.
Old Aug 18, 2013 | 05:45 PM
well to be perfectly honest i am not even sure what is to much for grinding off of that cross member. so an aftermarket traction bar is what would replace that oem crossmember?
Old Aug 18, 2013 | 06:20 PM
zrickety's Avatar
Yes, get full-race or ESP
Old Aug 18, 2013 | 07:53 PM
EFmine's Avatar
http://www.vexmotorsports.com/Innova...-_p_14310.html
i have this one from Innovative, no complaints from me yet
Old Aug 19, 2013 | 12:12 AM
lsdisk0's Avatar
I was just about to suggest the same one just from password JDM lol.
Old Aug 19, 2013 | 05:30 PM
crvtectim's Avatar
ETD has been good to me.
Old Aug 19, 2013 | 06:37 PM
civicb1812345's Avatar
if your cheap just cut the whole lip of it off, i habe about 1-2 inches cut in mine for my 4-1 header, be warned though 4-1 headers sit loooowwwww to the ground. my crx is stock height and they sit about 6 inches from the ground
JDM_ego2033
Welding / Fabrication
Apr 20, 2018 06:00 AM
GearSpeedKelvo
Feb 5, 2016 07:03 AM
CafFiend_EG6
Feb 23, 2010 03:27 AM
juanchoenuncrx
Apr 13, 2008 10:10 AM
bensonwrx
Apr 15, 2003 08:04 AM
