B16A Cylinder 1 Misfire
I have a 1989 Honda Civic HB with a JDM B16A SiR I motor. It doesn't seem to fire cylinder 1. I'm going to conclude that it is leaking radiator fluid through the head gasket into the cylinder, flooding the spark plug and causing it not to fire.
So I'm going to replace the head gasket and the head studs. OEM and ARP probably. Where can I get an OEM gasket and ARP head studs for a good price? Is eBay my best bet? On the honda parts website, where I usually buy parts from, the head gasket is about $70. Is that a fair price? And as far as the head studs, is $120 the going price? Checked eBay real quick and that's what I saw. I guess I can hunt around for some unused ones in the for sale area.
Thanks.
Thanks.
A misfire on 1 cylinder normally will not cause the car to die and will not cause a high idle. Are you getting good strong spark? I would go head and replace the cap, rotor, plugs and wires and see if that helps. A blown head gasket can cause a misfire if that cylinder is getting coolant in it.
Ok so no spark going to cylinder 1 right? So you are getting spark on the other 3 cylinders just not #1? Sounds like a bad plug or wire. The dizzy will either fire or not so if you are only getting spark dropping out on 1 cylinder than that leaves the only things in between the dizzy and that cylinder which is the wire and plug.
Make up your mind here man first you say spark then no spark and now spark again. IS the spark hot and strong? It should be a bright blue spark. The cap and rotor could have carbon build up on them cause the spark to be weak on that cylinder.
This is just a misunderstanding. It does spark. The cylinder does not fire. In my original post I said that you can pull out the spark plug wire and nothing happens, meaning the cylinder wasn't firing at all. I also said I removed the plug and wire and saw spark while cranking the motor.
The distributor is new, but I'll take it apart just to check for something anyways.
Dont just start pulling the head off with out knowing you have a head gasket issue. For $20 you can get a block test kit to test for hydrocarbons in the coolant. Head gaskets normally dont just blow. You have to over heat the car or have head lift.
This is my first honda engine I've really messed with. I sure do miss the simplicity of Air cooled VWs.
viking-101
Apr 17, 2012 07:43 PM
blazespeedshop
Sep 19, 2004 10:54 AM
