94 accord ex wont start
Old Aug 17, 2013 | 02:59 PM
ak768's Avatar
Default 94 accord ex wont start
went out the other day after hearing a nise in my blower fan.took it off and cleaned it out. (BIG mouse house) car ran fine. went out today and all it wants to do is turn over but not start. Car has 340,000 miles on it and i don't have the money for a mechanic. My question is can i disconnect the fuel line at the fuel rail and see if it is getting gas there? when i turn the car on i can't hear the pump pumping but i never could hear it even before. Its just that this seems to be the easiest point to get to to see whats up.
Old Aug 17, 2013 | 05:00 PM
mrj_accord's Avatar
Default Re: 94 accord ex wont start
try swapping out the main relay under the driver side dash.
Old Aug 17, 2013 | 10:16 PM
Laura Ilkenhans's Avatar
yes you can be prepared for gas to spurt at you wrap arag around it to keep it off your face
Old Aug 17, 2013 | 11:50 PM
holmesnmanny's Avatar
Just turn the ignition to on then turn it off. Then open up the bolt on the fuel rail and see if it sprays. It if doesn't then you know fuel pump isn't working. Very easy to do. If you think it sprayed but aren't sure. Just put the bolt back on tight, prime the fuel pump again, then take it back off and see if it sprays. You can also just put that hose in a jar of some sort and have someone quickly on off the ignition, but that can be messy and you'll just be wasting fuel.
Old Aug 18, 2013 | 03:19 AM
ak768's Avatar
Would that be the same relay as a 93?
Old Aug 18, 2013 | 04:22 PM
mrj_accord's Avatar
yessir!
CanadianAccord1
Mar 27, 2016 11:01 PM
guamtrain
May 20, 2009 05:57 AM
whitehf
Aug 6, 2006 01:22 PM
Marcpb443
Jul 16, 2006 08:59 PM
spettinger
May 25, 2005 11:46 AM
