92 acura not shifting
Old Aug 16, 2013 | 08:23 PM
ninja_integra's Avatar
Default 92 acura not shifting
ill start off saying im a new user im trying to find out some info on why my integra is not shifting right the shiftier feels like it in neutral when i go to put it in a gear. but it will only go into 3rd and 4th none of the other gear will work i just replaced the clutch and before i did that it was working just fine i thought it might have been the linkage but that tight the only thing loose is the shifter its self right were it connects the the rod could that be the problem ?
Old Aug 17, 2013 | 06:40 AM
m4xwellmurd3r's Avatar
did you forget to put the sleeve inside your shifter before you bolted the linkage back to it?
Posted from Honda-tech.com App for Android
Old Aug 17, 2013 | 10:24 AM
Default Re: 92 acura not shifting
i thought i did but when i checked it was all there
konvikt
Jan 20, 2007 08:01 PM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
infamousALLMTR
Jan 30, 2002 09:30 AM
