JDM ITR Clusters > USDM Plug & Play
Old Oct 25, 2002 | 11:12 AM
Unlimited's Avatar
New User
Default JDM ITR Clusters > USDM Plug & Play
which years does it plug and play to and which years do you have to swap the instrumentations
Old Oct 25, 2002 | 01:06 PM
itr-j's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (Unlimited)
why is there no 2000-2001 JDM itr cluster that works?
or is there
Old Oct 25, 2002 | 01:07 PM
Cosworth's Avatar
Buy my Spoon cluster... it works on '98+ R.
Old Oct 25, 2002 | 01:09 PM
AssPenny's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (Cosworth)
Self promoting post *****
Old Oct 25, 2002 | 01:29 PM
Cosworth's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (AssPenny)
You're worse than me.
p.s. 96-97 JDM ITR cluster will need to have the gauges/mother board swapped w/ USDM/CDM gauges/mother board. I believe '98+ JDM ITR cluster will bolt right in.
-Sean
Old Oct 25, 2002 | 01:37 PM
skafia's Avatar
25 Year Member
I know that 1996-1997 ITR clusters only fit 94-97 USDM Integras. 98+ would require 98+ cluster...
Old Oct 25, 2002 | 01:40 PM
Cosworth's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (skafia)
JDM 96-97 can be made to work perfectly in '98+ UDSM ITRs.
Old Oct 25, 2002 | 01:41 PM
skafia's Avatar
25 Year Member
what do you have to 'rig?
Old Oct 25, 2002 | 01:45 PM
Cosworth's Avatar
Posted previously... you have two options (both work fine)
1. Swap JDM gauges (speedo, rpm, fuel, temp) into USDM cluster housing
2. Swap USDM green electrical film (motherboard) over to JDM cluster housing.
I like method 2 over method 1. Some people like it the other way.
Old Oct 25, 2002 | 02:21 PM
b18c-rDC2's Avatar
cosworth check im's...thanx
Old Oct 26, 2002 | 10:13 AM
skafia's Avatar
25 Year Member
But don't the pre 97 guage clusters have the 'cat' temperature icon?
Old Oct 27, 2002 | 01:24 AM
SMZ GSR's Avatar
Hey guys, i just had the same problems with my JDM ITR cluster. it's from a 2000-2001 (i believe since it has the little key icon above cruise control) and i have it in my 98 GSR. A few things didn't work correctly until i swapped the green circuitry on the back. Now everything works fine.
Old Oct 27, 2002 | 01:35 AM
hooptie157's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (SMZ812)
man these are pretty
Old Oct 27, 2002 | 01:39 AM
Reid's Avatar
Global Moderator
Default Re: JDM ITR Clusters > USDM Plug & Play (hooptie157)
Man, that's irrelevant.
Old Oct 27, 2002 | 02:05 AM
itr1244's Avatar
Old Oct 27, 2002 | 04:38 AM
NunRacer's Avatar
Default Re: JDM ITR Clusters > USDM Plug & Play (itr1244)
Pretty but irrelivent.
crx_253
Northwest (Sales)
Aug 15, 2010 09:33 PM
JDM_FRONTIN
Sep 14, 2007 09:47 AM
TURBODC4TEG
May 31, 2007 12:27 PM
xtremeness101
Oct 30, 2004 05:19 PM
