90 crx caster and Steering Axis Inclination (SAI) way off
Old Aug 16, 2013 | 02:14 PM
nicknack25's Avatar
Default Alignment problem 90 crx caster and Steering Axis Inclination (SAI) way off
So i just changed my inner and outer tie rods and got an alignment.
Here are my results:
I'm not sure if it's okay or totally off. Individually, Front left and Front right are way off, but the total front looks okay?
Don't really know much about alignment stuff..
Old Aug 17, 2013 | 05:52 PM
zrickety's Avatar
Default Re: 90 crx caster and Steering Axis Inclination (SAI) way off
Has the car been in an accident? You have some weird numbers. Camber is off all over, except the right rear is ok? Must be lowered? Overall looks good.
Old Aug 17, 2013 | 10:05 PM
nicknack25's Avatar
I don't remember if the first owner has gotten into an accident. I don't think he has though. And yes it is lowered on koni's/groundcontrols. Did the washer camber trick in the rears.
Old Aug 17, 2013 | 10:08 PM
nicknack25's Avatar
I'm asking because my car is still pulling to the left. I can tell the fronts are not straight either. When my left front (driver side) is straight, my right front is a little cocked outward. Went back to the shop and told em it's still pulling left so i got set up for an appointment tomorrow.
Old Aug 18, 2013 | 11:12 AM
zrickety's Avatar
Awesome, maybe their equipment was just a little off the first time. Did they say anything when it was done?
Old Aug 18, 2013 | 01:08 PM
nicknack25's Avatar
That's what I'm thinking. But no they didn't say anything about it just that it was off by almost 2 degrees.
Old Aug 18, 2013 | 01:09 PM
nicknack25's Avatar
Is the toe supposed to be the same on both left and right sides? I asked the guy and he said it doesn't matter just as long as the total toe is within spec.
00IntegrAllmotoR
Suspension & Brakes
16
Oct 24, 2009 07:08 PM
Renegade
Suspension & Brakes
22
Nov 15, 2005 08:08 AM
JDMhatchback20
Nov 17, 2004 09:06 PM
Boilermaker1
Mar 8, 2004 12:18 PM
