Transmission & Drivetrain Gearboxes, Differentials, Clutches
Input Shaft Bearing Stuck on Shaft
Old Aug 16, 2013 | 01:45 PM
theYBLEGAL's Avatar
Loved
Default Input Shaft Bearing Stuck on Shaft
Any good advice for removing the input shaft bearing from the shaft?
I can't get the gearsets out of the case because of this. The input shaft bearing failed to the point of missing 1/3rd of the *****, and the inner race is seized onto the shaft.
Trans is a Y21, hydro.
Old Aug 19, 2013 | 01:23 PM
Aquafina's Avatar
Default Re: Input Shaft Bearing Stuck on Shaft
Cut slots into it for use with a puller or just use a press.
Old Aug 19, 2013 | 06:43 PM
theYBLEGAL's Avatar
Loved
Just now got it out with a piece of wood and a mallet. Just took a couple mild taps and it came free.
Solved.
Old Aug 20, 2013 | 06:01 AM
theYBLEGAL's Avatar
Loved
Old Aug 20, 2013 | 11:41 AM
theYBLEGAL's Avatar
Loved
New problem!
How can I extract the outer race of the input shaft bearing?? Do I have to order a big blind hole puller? Autozone's rent a tool got out the countershaft bearing no problem but does not have an attachment big enough to grab this.
Old Aug 20, 2013 | 11:50 AM
theYBLEGAL's Avatar
Loved
Nevermind!
Success.
Put the remaining ***** and race back in, spaced the ***** with flathead screwdriver, and they had just enough grip that I could use the inner race and blind hole puller kit from autozone to knock it out.
garyc17
Feb 4, 2009 04:53 AM
Agent Daimon
Apr 3, 2008 05:04 PM
12345
Jun 24, 2005 07:04 AM
