Gas pedal not sensitive 97 civic
Old Aug 14, 2013 | 10:53 PM
Squidwerd's Avatar
Icon2 Gas pedal not sensitive 97 civic
When i press on the gas to lightly the gas pedal wont move and wont rev but when i press it a little bit more it goes to far and revs too high, is there a way i can lubricate some thing so the gas pedal wont be so stiff?
Old Aug 15, 2013 | 12:32 AM
NameGoesHere's Avatar
Default Re: Gas pedal not sensitive 97 civic
Shouldn't need to lubricate, but maybe adjust. You can adjust at the gas pedal or adjust the throttle cable. As with do anything yourself, check to make sure you will do it correctly.
But if I am understanding correctly, you barely press in the gas and it's like it is flooring it?
That is something a tight or loose throttle cable wouldn't do, Maybe the Throttle Position Sensor is faulty?
Old Aug 15, 2013 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Clean your throttle body and throttle plate. Also check and readjust your throttle cable if needed.
85crx509
Sep 3, 2008 11:10 AM
VietCloud7
May 6, 2008 04:46 PM
91da9ls
Jan 29, 2007 04:00 AM
mr poo
15
Jun 14, 2006 08:09 PM
midorigreen.
Mar 16, 2003 07:40 AM
