integra runs the dies after a little driving
Old Aug 14, 2013 | 11:52 AM
94whitecivic's Avatar
Default integra runs the dies after a little driving
hello i am looking into buying a 96 integra gsr my friend is selling the only thing he sed was wrong was it will start, drive it 30 miles or so then dies after that it dont want to start. you have to wait a while for it to start back up again. pls help thanks
Old Aug 14, 2013 | 11:59 AM
kyden's Avatar
Default Re: integra runs the dies after a little driving
look up main relay repair.
Old Aug 14, 2013 | 12:56 PM
think thats what it is?
Old Aug 14, 2013 | 02:28 PM
IN VTEC's Avatar
Ignitor has a similar failure. It gets hot and craps out. When it cools down, it start working again.
Old Aug 14, 2013 | 02:47 PM
B_Swapped93's Avatar
x2
OP does your tach jump/spaz out sometimes ?
Old Aug 15, 2013 | 12:35 PM
have no drove the car yet. also what is ignitor? I hope its an easy fix I really want this car. I thought it might be the coil or fuel pump but I have not done any test yet myself
Old Aug 15, 2013 | 12:39 PM
I was also thinking a possible computer problem but once again im not sure
it's in the distributer super easy to replace same with the fuel pump or coil.
Old Aug 15, 2013 | 08:38 PM
ok sound like an easy job. just found out its a 95 obd1. will the distributer from a 94 civic work i used it on a b20 its obd1
Old Aug 16, 2013 | 10:01 PM
IN VTEC's Avatar
That's the ignition coil, not the igniter aka ICM in the service manual.
Old Aug 25, 2013 | 05:07 PM
ok i found out what happened i swapped the ignition module in the distributor with one that came out of a 94 civic and it has not died on me after that. thanks for the help
E Swift
Jul 10, 2019 03:46 PM
Smackinassvtec
Jan 16, 2014 01:35 AM
DvrkLord
Jan 3, 2014 05:13 PM
MechEng
Oct 26, 2013 01:25 AM
SpoolinEK9
Mar 15, 2005 04:25 PM
