Transmission & Drivetrain Gearboxes, Differentials, Clutches
Throwout Bearing or Input Shaft Bearing?
Old Aug 13, 2013 | 05:45 PM
TimelessLlama's Avatar
Default Throwout Bearing or Input Shaft Bearing?
Alright so I have searched the great depths of HT and I am a little confused. I want to figure out what's wrong with my trans: Is it the TB or ISB? When my foot is completely off the clutch pedal I hear a rattling noise. When I completely press the clutch pedal the noise goes away. That's not the only thing though. When I'm driving and I downshift, from 3rd gear to say 2nd, I hear a loud whining noise. Could it be both the TB and the ISB? How long can I drive like this?
Old Aug 13, 2013 | 06:13 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Throwout Bearing or Input Shaft Bearing?
Either way your going to need to replace one or the other or possible both.
So might as well get busy.
Old Aug 13, 2013 | 06:31 PM
Former User's Avatar
ISB
Old Aug 13, 2013 | 07:21 PM
Originally Posted by RonJ@HT
ISB
I don't mean to sound like an *** or disrespect you, but how do you know? Has this happened to you before?
Old Aug 13, 2013 | 07:23 PM
Originally Posted by TimelessLlama
how do you know?
Old Aug 13, 2013 | 07:35 PM
jbpnoman's Avatar
Like RonJ said, foot off pedal noise = ISB. Foot on pedal noise = TOB. Extremely common problem. Do yourself a favor, if you plan on doing the work yourself, get a factory service manual, and the full rebuild kit (bearings, seals, and synchros) from Syncrotech. You'll be digging deep into the transmission - no reason NOT to replace all of the wear items while you're in there. Your main seal would also be easy to do while you have the transmission off, as would a new clutch disc, and having your flywheel resurfaced.
Of course, that list is just the best idea, best practice list - it isn't all necessary, but I would highly recommend it from personal experience.
Old Aug 14, 2013 | 06:00 AM
kyden's Avatar
if it doesn't grind, a synchro kit is completely unnecessary. I would replace all the bearings though, as it could also be a countershaft bearing.
Old Aug 14, 2013 | 06:36 PM
HondaCivicSE's Avatar
input shaft bearing
Old Sep 24, 2018 | 01:59 PM
Buster _'s Avatar
I’m doing both I have the same problem with the throw out bearing and since I’m going that far might as well replace the back side!
shermanyang
Dec 1, 2012 11:24 AM
NOTUNINGNONADA
Aug 15, 2010 05:57 AM
jr000
Feb 29, 2008 01:39 PM
IGotVTECyo
Nov 15, 2006 06:05 AM
ghatch
Sep 6, 2005 09:28 PM
