Grinding noise that stops when i press on the clutch
Old 08-12-2010, 05:50 AM
NOTUNINGNONADA's Avatar
Icon2 Grinding noise that stops when i press on the clutch
This only happens in 1st 2nd and 3rd...sometimes it does it sometimes it dont but its like a grinding noise but it stops when i press on the clutch. but if i dont go past a certain rpm it doesnt make the noise...what is the diagnosis??
Old 08-12-2010, 06:02 AM
D Griff's Avatar
Default Re: FUNNY NOISE
Is it like a kind of clattering sound? It probably is something with your clutch. Maybe a throw-out bearing.
Old 08-12-2010, 09:56 AM
Former User's Avatar
Sounds like a bad input shaft bearing inside the transmission:
http://www.d-series.org/forums/trans...ng-change.html
Old 08-15-2010, 05:54 AM
is that hard to change??
Old 08-15-2010, 05:57 AM
the noise is more like if you got a philips head screwdriver bit on the end of a drill but it is too big for the screw you want it for...and when u use the drill it sounds like you are rounding out the phillips head don the screw
but it doesnt get faster or louder as you rev...stays constant
Tyler Harteau
01-04-2021 08:45 PM
integra_101
10-16-2013 01:29 PM
shermanyang
12-01-2012 11:24 AM
usdmed9
05-17-2011 10:46 AM
rdssk8rcs1
07-23-2008 08:00 AM
Quick Reply: Grinding noise that stops when i press on the clutch
