WTB: Integra Type R DC2 Rear Trailing Arm Knuckle and 5 lug Hub
like the title says i picked up a 36 mm 5 lug conversion for my teggy, however only came with the front and one rear missing the other rear (not sure which one it is ill update later today) the whole trailing arm was bent due to accident so its useless so i need everything complete. if i have no luck ill use a reg trailing arm and just going to need the 5 lug hub maybe caliper. if no luck ill end up having to build my own using a rsx type s hub and it has to be a rsx type s, also heard a 97-01’ Honda Prelude SH hub would work but not familiar with setup. so show me what you got.
Damn, I also found another passenger too, I might need the lines (my passenger was cut), rotor/brakes will you part out?
I got rid of the caliper a few years back, I have the rotor tho. I might have Rear disk brake lines as well, I'll have to look.
743power
Dec 8, 2003 01:30 PM
