Interior lights won't turn on when door is ajar?
Old Aug 12, 2013 | 09:43 PM
TheOnlyBobaFett's Avatar
Icon3 Interior lights won't turn on when door is ajar?
Just got my 91 Da9 integra and the interior lights won't turn on when the door and/or hatch is open. How do I fix this? is it a relay or fuse?
Old Aug 13, 2013 | 06:47 AM
4doorpimpn's Avatar
Default Re: Interior lights won't turn on when door is ajar?
Google dammit... LOL -- I had the same problem.
http://www.team-integra.net/forum/12...esnt-come.html
Old Aug 13, 2013 | 12:10 PM
fcm's Avatar
fcm
Old Fart
For the dome light, [doors] it is most likely the door pin switches, they get rusty, you can try and clean them or just replace with new ones.
For the hatch light, check the bulb as that switch is in the latch and hardlt ever fails.
I assume you checked the fuse, if not, check fuse 14 - 15A, [hot at all times] in under dash fise box.
Question, does the door open indicator or hatch open indicator in the gauge cluster light up if a door or hatch is open, if not also check fuse 23 - 7.5A, [hot when ign. switch is on] in under dash fuse box. 94
Old Aug 21, 2013 | 04:16 PM
I have got the doors to work just the hatch is not lighting up. Where is the switch located on the hatch?(the front switches were corroded).
Old Aug 21, 2013 | 04:42 PM
fcm's Avatar
fcm
Old Fart
The hatch switch is in the hatch latch.94
Old Aug 21, 2013 | 05:03 PM
All right thanks you have been very helpful. I will get a new bulb for it and see if that helps too. The drivers side pigtail connector for the front door needs to be replaced/ cleaned? It is having a tough time making connection any trouble shoot you have used?
Old Aug 22, 2013 | 12:49 PM
fcm's Avatar
fcm
Old Fart
You can clean them sometimes, however I always just replace them with new ones.
If the hatch light and the hatch open warning lights do not turn on the problem must be the switch or wiring, access the hatch switch wiring plug, [single lead, green/black] and make sure it is plugged in, if so, unplug it and ground the lead. if light and/or warning light turns on, [ign. must be on for warning light] the switch is bad, replace the latch. 94
Old Aug 22, 2013 | 03:45 PM
Thanks I took the latch apart and heavily clean the switch and replaced the bulb. It now works great! I disassembled the front door ajar switches and cleaned them as well and they work as well. Thanks again for the info and support
Old Aug 22, 2013 | 04:24 PM
fcm's Avatar
fcm
Old Fart
and YW. 94
Old Aug 24, 2013 | 06:56 AM
eugew23's Avatar
Door ajar light in the dash does not light up when the doors to my DB Integra are open. Dome lights do not work either for the doors. Are these issues connected?
Old Aug 24, 2013 | 07:44 AM
fcm's Avatar
fcm
Old Fart
Yes, both are controlled by the door pin switches. 94
stuck amals
Sep 29, 2014 09:50 AM
boostedef123
32
Aug 9, 2011 08:29 AM
tonydize21
Jul 3, 2011 07:52 PM
Ski_Bum
Apr 1, 2009 03:18 PM
hagrid
Nov 22, 2002 08:26 PM
