Brake Booster removal
Old Aug 12, 2013 | 11:43 AM
j3wman's Avatar
Default Brake Booster removal
hey so im taking the brake booster out of my ef hatch right? gonna replace all of it with a prelude master cylinder and booster. anyway...
driverside top bolt... HOW THE F ARE YOU SUPPOSED TO GET THAT OUT?!?!?! or do i gotta take the whole dash apart?
Old Aug 13, 2013 | 08:55 AM
droopy128's Avatar
Default Re: Brake Booster removal
Just gota snake your way in there..
Old Aug 13, 2013 | 09:09 AM
Riceburner247's Avatar
I've done it without dash removal, but you'll be using an assortment or flex ratchets, extensions, wobblies, and long or deep sockets. Or even open ended wrenches, I can't remember.
Old Aug 15, 2013 | 07:19 AM
j3wman's Avatar
****... thats what i was afraid to hear
Old Aug 16, 2013 | 05:19 PM
EFnCRX's Avatar
Pull your dash ryan I'll help you.
Old Aug 17, 2013 | 11:43 PM
Jerms's Avatar
**** pulling the dash I installed the da 15/16 master and booster without removing dash and Im 6,5 ... gonna tighten it down tomorrow
If I can do it anyone can and I have huge freaking hands
Old Aug 18, 2013 | 06:54 AM
99teggsr's Avatar
You do not need to remove dash. I was able to do this with a ratchet and wrenches. Just takes time and patience. I found the easiest way is to recline your drivers seat and lay stomach up on seat with your heat under dash. Also, if using a ratchet for the top right bolt make sure you disconnect ratchet and tighten with wrench the rest of the way otherwise you wont be able to get ratchet off. I drove around for over a month with my ratched stuck on that bolt from making this mistake.
Old Aug 18, 2013 | 02:18 PM
EFmine's Avatar
Dont pull the dash!!! way too much work.
I took my seat out of the car to get the most room, just lay on you back and go slow. its a b*tch nut forsure, but its not impossible.
Used a 1/4 drive with a small swivel
tacosandbeans
Nov 7, 2010 05:01 PM
88 EF Hatch
Dec 9, 2008 08:46 PM
ej6hatchie
Paint and Body
May 14, 2008 09:48 AM
Sloshy
May 11, 2007 10:42 AM
supracrx
22
Dec 12, 2006 08:23 PM
