93 Civic AC enaging/disengaging quickly
Old Aug 12, 2013 | 11:43 AM
j_smith01's Avatar
Default 93 Civic AC enaging/disengaging quickly
Hello,
I have a 93 civic. swapped the ac with a 95 civic 6 months ago and everything was ok until recently. The parts I used were all new except for the compressor and the hoses which I took from another 95 civic.
Sometimes, when I turn on the AC, it works for a few minutes, then the compressor starts disengaging and engaging quickly which make me turn off the ac. During this time, the condenser fan does not come on. Other times, ac works as usual and condenser fan comes on also.
I appreciate for advise on what might be the problem.
Old Aug 12, 2013 | 11:44 AM
Former User's Avatar
Default Re: 93 Civic AC enaging/disengaging quickly
Fix this^ and you'll likely fix the problem.
Old Aug 12, 2013 | 12:47 PM
nealnanoHX's Avatar
Yeah with the condenser fan not working head pressures will increase and the compressor will cycle on and off because the high pressure switch is disabling the clutch in an effort to save the system from blowing up, but the AC wants to work because you have it on so it tries to turn back on again. Fix the condenser fan issues and you will most likely have the problem fixed. It is also worth it check the R134 charge to be sure it is not low.
Old Aug 12, 2013 | 08:01 PM
j_smith01's Avatar
Noticed today that, the condenser fan starts working when I spin the fan. Looks like the fan motor is bad and needs replacement?
Old Aug 12, 2013 | 08:09 PM
Probably
David Guevara
19
Apr 9, 2016 06:44 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
knotcher
Jun 29, 2015 10:34 AM
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
stockEJ
Aug 6, 2008 06:46 PM
