1990 crx with zc sohc problem
Old Aug 11, 2013 | 10:14 PM
loctaz's Avatar
Default 1990 crx with zc sohc problem
wazzapenin guy im new to site and i have a small problem thats been kicking my a$$ and brains and was looking to see if anyone can shed some light...
now to the problem.. its the old over heating problem.
to start i bought the rex allready with the swap so dont know much about how it was built what i can tell u is the parts and test i have done and replace
replace, water pump, thermostat, coolant, coolant temp gauge, make sure theirs no air in the coolant system did the water in the oil test all good no white smoke comes out and finally did a compression test all cylinders between 160 and 170 psi and fans work thru a switch
after all this the rex clusters needle still get to the red line after only 5mins of run time any suggestions???? the last thought was the head gasket are backwards cause the bottom hose is cold to the touch but the upper hose does get hot any help would be appreciated
Old Aug 11, 2013 | 10:53 PM
d6v3's Avatar
Default Re: 1990 crx with zc sohc problem
Very possible the rad is clogged... try taking it out and back flushing with a waterhose.
what your describing is lack of flow top hose hot bottom much cooler almost ambient temp...
Old Aug 12, 2013 | 07:55 AM
BroTucker's Avatar
How hot has it gottten. Have you run it into the red for any amount of time?
Old Aug 12, 2013 | 10:42 PM
loctaz's Avatar
thnks for your comments.......will try and run water with a hose and i have not run the vehicle yet cause im not sure if i would damage the engine so it heats up sitting in my drive way
Old Aug 21, 2013 | 07:17 PM
D_Doobered's Avatar
I just replaced my radiator cap that was giving my problems
well I hope it was lol I still need to flush the radiator and replace the temp sensor because it isn't working at the moment
BigJerm333
12
Aug 5, 2014 08:01 AM
EG92DX
Aug 8, 2013 07:09 PM
md88hfcrx
10
Dec 20, 2005 01:08 PM
Jaydo
20
Jun 28, 2004 10:17 PM
91civicguy
Honda Motorcycles
Nov 29, 2001 10:48 PM
