Broke LCA to rear hub bolt head, safe to weld head on?
Old Aug 11, 2013 | 03:03 PM
terqui's Avatar
Default Broke LCA to rear hub bolt head, safe to weld head on?
So i installed my coilovers this weekend and broke the head off the bolt, like in this picture
Just the head came off, the bolt is roughly flush with the metal on the hub. I need to car to get to work this week. Would i be safe welding a washer or similar piece of metal to the end of the broken bolt? It only needs to be a temporary fix for a week or so until I can get new parts. I later figured out that i didnt have to remove this bolt to get the stock shocks off, but that was after I made this mistake.
Old Aug 11, 2013 | 03:10 PM
knoxrocks222's Avatar
Default Re: Broke LCA to rear hub bolt head, safe to weld head on?
Just go to your local auto parts store and get an easy out man, your going to need more than a bolt when you get done welding on your lca....unless you plan on replacing them anyway
Old Aug 11, 2013 | 03:12 PM
instrument's Avatar
the worst that could.happen.is.fiery death.
Old Aug 11, 2013 | 10:11 PM
sfcivicex's Avatar
When i had my LCA changed on my integra a bolt head broke.
Shop welded another head to the bolt to get it out.
Ive heard you can drill them out
Old Aug 12, 2013 | 03:38 AM
tercel95's Avatar
I have had the same bolt break on me on 2 different cars. I cut the LCA out with a sawz all, then drilled the bolt out until I could get it to spin. Then I used a pair of vice grips to work it the rest of the way out.
bow tie
Nov 15, 2008 05:11 PM
Beau Gotti
Sep 10, 2006 12:25 PM
redm3turbo
10
Jul 20, 2006 01:36 PM
yellowdcn
Jun 26, 2005 10:37 AM
ltho1998
Aug 16, 2003 06:59 PM
