Civic 94 sound like a subaru
Old Aug 11, 2013 | 01:24 PM
elsicario12's Avatar
Default Civic 94 sound like a subaru
Okay i have a 94 civic ej2 with a b18b1 it start sound like a subaru last week i change the spark plugs and wire and still sound and cylinder 2 is not firing but it has compression. Also my timing is off so maybe that could be the problem and i have CEL #8 which is the TDC sensor but what you guys think could be?
P.S also idle rought and the rpm is under 1k on neutral
Old Aug 11, 2013 | 02:05 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Civic 94 sound like a subaru
Sounds like timing off.
Old Aug 11, 2013 | 03:51 PM
Actually maybe it is i check and the two lines of the cam gear are not lined sooo that means the timing is bad??
Old Aug 11, 2013 | 07:28 PM
B18CivicHatch's Avatar
How much compression do you have on all cylinders because i had the same setup in my 90 hatch and it was a bad valve in my same exact cylinder
Also just to add that if your timing is off it is theoretically possible that a valve may be damaged the easiest way to get your timing perfect is to insert a small allen wrench into the holes above the camshaft holder right near the camgears and that way your cams will always perfect and just make sure you have enought tbelt tension.
Old Aug 13, 2013 | 01:02 PM
Okay i didna compression test and the result was 1:155 2:179 3:155 4:180 so the compression is normal or not???
Old Aug 13, 2013 | 02:38 PM
Freemananana's Avatar
Looking forward to more from this because I have the same issue.
One of my cylinders isn't firing and has compression. Have you checked for spark and fuel?
My compression on a B16 was closer to 210 across all cylinders. Not sure if the B18B just has lower compression.
Old Aug 13, 2013 | 02:50 PM
B_Swapped93's Avatar
that's a bit too much variation 155 -180. you've already said timing was off have you fixed it yet ?
Old Aug 13, 2013 | 03:51 PM
Will fixing the timing really change this?
Old Aug 13, 2013 | 03:54 PM
FFS fix the damn timing ! I don't know logically it should but hard to say with out it fixed
Old Aug 13, 2013 | 11:29 PM
Actually that compression test was wrong the shop made a mistake so i decide to do one by myself and i got 1:180 2:180 3:175 4:180 yes the spark plugs are new and the injectors are working im gonna try to fix the timing today and i let you guys know!!
Old Aug 14, 2013 | 12:46 PM
Alright! I'm really interested in seeing you fix your issue. So I can try whatever worked for you.
Tiffany Hurst
Nov 23, 2017 07:02 AM
93ej2civic
29
Feb 21, 2016 06:02 PM
Powered by VTEC
Jan 25, 2008 10:13 AM
Samuels
May 26, 2007 08:34 PM
Cone
Jun 23, 2003 02:51 PM
