92 honda civic sedan dx ac troubleshooting
hello folks. i have a 92 honda civic sedan dx. i just change out the drier, ac compressor, expansion valve, climate control, new belts on my car. i went to a local mechanic shop and have the freon charge in. i have no leaks and my ac will blow out cold air for a good 5-10 mins after that ac compressor will shut off. i turn off the car and let it sit for like a good 10 min and turn it back on. the ac will kick back on and it will be cold again but will shut off after 5-10 min. does anyone know what causes this? can it be a bad relay? or pressure switch?
hey @ronjo@ht. how you been? its been a while. yes the condenser fan still continue running when the ac compressor clutch disengage.
Been good. Thanks.
This^ rules out the pressure switch, thermostat, and heater control panel.
The problem could be a bad compressor clutch relay, ECU, or compressor clutch (gap or coil). Start by testing the relay, the armature plate/pulley gap, and the field coil.
the ac compressor is brand new from the local auto part store. that same problem was doing with the old ac compressor so i bought a new one thinking it that was the problem but it wasn't.
David Guevara
19
Apr 9, 2016 06:44 AM
PL_RACER
Honda Civic (2006 - 2015)
Jul 24, 2012 07:20 PM
fixmyac
Jan 26, 2012 11:59 PM
nafreak
Apr 16, 2009 12:09 PM
JDMCRX
Jun 4, 2005 12:35 PM
