C917 not working?
So I tested my voltmeter yesterday on the battery, it works. So I went to wire it up today, and using advice from RonJ to connect the positive with a spade bit to the C917 connector on the under dash fuse box, I did that, with a direct line to the battery for the other line. I turned the car to the ON position, and even started the car, but nothing happened. I checked all connections, and they are fine, and I even took the wire out of the spade bit and touched it directly to the 917 connector and nothing. What's going on?
Can ANYBODY help me? Also, I unplugged the positive end of the voltmeter, the one that goes to the C917, and left the car in the parking lot at my job. Came out 4 hours later to find my battery COMPLETELY dead, and took 20 minutes to jump start it. I have no idea why, since the positive end was disconnected. Maybe there is a short? I don't know... please, somebody help me. And yes, I did buy a test light, so I can use that too...
With the clip of your test light connected to a clean peice of metal for ground touch the C917 spade with the key in the run position. Does the test light turn on?
I will check tomorrow after work. But why did the battery drain? I didn't even have the thing fully wired up, so even if there was a fluke and the fuse box was getting power it wouldn't have affected it.
notmightydx
Oct 16, 2008 06:55 PM
