99 Civic DX Coupe 5spd - A/C Compressor
A/C Compressor is dying....nearly dead. Trying to find a new one but have no idea how to tell if it's a Denso or Sanden.
I've read a few instances where people were told it shouldn't matter and they buy one and it's the wrong one.
Is there any way I can be sure?
Thanks
Thanks
The armature plate is dead giveaway. Thanks!
I changed the timing belt with success, but I've never done anything with A/C ever. Is this something I should hire someone to do or is it less taxing than timing belt/water pump?
I actually think the clutch is the culprit, but I've run it too long in this condition and would just like to replace the whole thing. I asked the shop that did the timing belt on my other civic, they said since the car had over 75K miles, they didn't want to just replace the compressor, they wanted to do the whole system at the cost of $1150. I have no problem with doing that, the parts all in all are not that expensive, so Imagine it must be labor intensive by their estimate.
I understand the removal of the compressor, adding the oil, new o-rings, but what I don't don't know how to address the capture of the refrigerant, how to vacuum the system, and or how to add the new refrigerant.
Also do you think it's necessary to do the condenser/evaporator as well?
Thanks again.
What are the symptoms? What makes you think the clutch is bad?
If only the clutch needs to be replaced, it's possible (but tricky in the tight space) to replace the clutch without removing the compressor or disconnecting the refrigerant lines.
Well, I think that was the problem at the start. Now, it kicks on and off constantly and grinds. Only cools for about 15 min in the heat of the day and then blows warm air.
Seems like compressor pulley to me. Sounds like you're trying to find a way for it not to be the whole compressor. Must mean the issues I was concerned with are not something an average joe can address (collecting old refrigerant, vacuuming, etc.)
Could be the pulley and clutch.
Can you post a video of the clutch acting up and making noise?
If the clutch seems likely, I'd recommend you try replacing the field coil, pulley, and armature plate.
Average joe can do the job. The only thing that a shop needs to do is recover the current refrigerant in the system.
Here's the video
http://s26.photobucket.com/user/txcz...025PM.mp4.html
You can see the armature plate catch while the A/C is off and then there is what looks like wobble after the A/C is turned on. It's louder than I realized under the hood.
Looks to me like the pulley is wobbling in the video. Do you agree?
If so, I'd definitely start here:
I think our posts crossed. Yes, definite wobble. I'll start there. Would this be causing the compressor to freeze up on days like we've been having and stop blowing cold?
Again, a member who I have a lot of trust in, stated that the clutch can be replaced without removing the compressor and disconnecting the refrigerant lines. This way, there's no need to recover refrigerant and oil, replace receiver/dryer, evacuate, leak test, and recharge with oil and refrigerant.
I guess you decided to replace the compressor.
Not sure. Call some shops that specialize in automotive A/C to do some price comparisons. I personally wouldn't pay more than $50.
Here's a link to A/C tools that AutoZone rents for free.
http://www.autozone.com/autozone/acc...oning/_/N-26vf
