Ls/v swap
Hi everyone I right now have a stock 94 cx hatch with a b15 in it. I want to put in a LS/Vtec motor. Does anyone know everything I need to do a complete swap. If someone can tell me that would be great. Thanks
hi there.. i have a little issue with mine but i can tell u what u would need to build or setup urs..
- ls/vtec kit
- head gasket dial pins (to align the head gasket on position)
- 1995-2001 integra gsr or 2000-2001 civic si head gasket
- p28 ECU chipped
- obd2 to obd1 jumper harness conversion (for the ECU) in case the head ur trying to use is from 96 and up
- obd2 to obd1 distributor conversion harness in case ur head is obd2 (96 and up)
- timing belt
- water pump
- manifold and header gaskets
i thinik thats it..
im looking for a obd1 vtec distributor thats the only problem im having on my swap my dizzy gave up on me so make sure thats in working condition before u do the swap.
Good Luck
- ls/vtec kit
- p28 ECU chipped
- timing belt
- water pump
i thinik thats it..
Good Luck
Check out this thread. You can find everything you will need to do this swap and make it reliable
http://www.b20vtec.com/forums/b-seri...tec-guide.html
kaddi88
Oct 6, 2008 07:55 AM
luv2boost
Apr 15, 2007 07:22 PM
