93 civic Battery Drain. HELP
Old Aug 7, 2013 | 04:29 PM
jroderick619's Avatar
Icon2 93 civic Battery Drain. HELP
My Battery Drains.
dont know where to start but, basically
when i DONT start my car for a good 23hrs (i timed it)
my battery dies..
I uninstalled my Sub, Amp and Dome Light (it only turns on when on DOOR mode, and on ON position SOMETIMES and when in OFF position it does not turn off, it just Dims).
i'm still running Fog Lights
i bought a Yellow Top from Autozone.
Replaced it 3x I'm now on my 4th New Yellow Top. LOL
WHAT I DID SO FAR..
I started my car, popped the hood, took Battery out and the car still runs..
WHAT ELSE CAN I DO and WHAT DO I TEST FOR..
I also checked all my fuses. all is in good and working condition.
another question
in general, if its not GROUND correctly. what happens?
So basically just to keep my car working normal i have to START her up twice a day...
SMFH WTF
Old Aug 7, 2013 | 05:44 PM
1dirtyeg4me's Avatar
Default Re: 93 civic Battery Drain. HELP
you need to do a amp draw test. you have a circuit that is drawing power when your car is off.
Old Aug 7, 2013 | 06:20 PM
NVturbo's Avatar
O.G. triple O.G.
loose ground. A friend of mine had this issue in a '98 Integra. He somehow removed one of the ground and forgot to tighten it back.
Old Aug 7, 2013 | 06:49 PM
EJ8mike's Avatar
This.
Check youtube on how to do this. Need only a multimeter.
Old Aug 7, 2013 | 06:50 PM
EJ8mike's Avatar
Oh and do u have an aftermarket alarm?
Old Aug 7, 2013 | 07:19 PM
Yes, i forgot to mention that i have a after market alarm.. i dont recall the name of the alarm. it was already installed in the car when i got it.
ok, i have a multimeter.. where do i check? and i'm looking for anything that reads 12amp? how would i know if its supposed to be a constant or not?
Old Aug 7, 2013 | 07:21 PM
um what happened? what are the effects of not having a proper ground?
i apologize for the noob questions hahah
Old Aug 7, 2013 | 08:47 PM
Former User's Avatar
A bad ground won't cause battery drain.
Watch this:
Old Aug 8, 2013 | 02:44 AM
NVturbo's Avatar
O.G. triple O.G.
I'm going to disagree Ron. It happened after I installed a kill switch on his car. The following day after the K/S install, he took his car to someone to replace something in the engine bay and the guy had removed one of the grounds and didn't reinstall it. He called me up asking if I did something to the car because the battery drained on him. After checking carefully, it was a loose ground.
Old Aug 8, 2013 | 04:27 AM
EsotericImage's Avatar
Retired Moderator
Never herd that before. Loose ground causing battery drain?!
Impossible.
Alarm causing parasitic draw, all the time.
Old Aug 8, 2013 | 05:11 AM
black97civic's Avatar
A ground is not going to drain the battery. Sounds like he thought the battery was dead but it ended up being a loose ground. A loose ground can act like a dead battery.
Old Aug 8, 2013 | 08:16 AM
NVturbo's Avatar
O.G. triple O.G.
Impossible.
I'm just relaying what he said. By the time I was able to check it out, he claims it was fixed.
Old Aug 8, 2013 | 08:33 AM
Watch this:
How To Perform a Parasitic Draw Test - EricTheCarGuy - YouTube
THANKS WILL DO!
jdmtim27
Jun 20, 2011 10:51 PM
old-sk0ol
Nov 26, 2008 09:57 AM
dannycraq
May 29, 2008 04:04 PM
silvervtecrx
Feb 21, 2005 11:04 PM
miataguy
Dec 31, 2002 08:38 AM
