D16A6 or D16Z6?
Old Aug 7, 2013 | 04:37 AM
screamin_demon's Avatar
Default D16A6 or D16Z6?
I have a d16a6 right now but it seems everytime i go to get parts they never seem to match up. Im wondering if i should just swap the head out to the head thats suppose to b on it or just do a whole engine swap? What do u guys think and im on a budget.
Old Aug 7, 2013 | 05:12 AM
nealnanoHX's Avatar
Default Re: D16A6 or D16Z6?
Dont really know what you are asking here
Old Aug 7, 2013 | 05:17 AM
Discosteak's Avatar
the A6 bottom end has steel mains, I would swap the head.
Old Aug 7, 2013 | 05:22 AM
Fliptard's Avatar
a6 and z6 and basically the same bottom end, they are the best d series bottoms. if you do a mini-me, (a6 bottom with z6 head), you will have to make sure you do everything correctly and get the timing dead on.
Or just find a full z6 swap and drop it in.
Old Aug 7, 2013 | 06:25 AM
Discosteak's Avatar
If you cant time a Sohc correctly you shouldn't be working on cars.
Old Aug 7, 2013 | 06:36 AM
Fliptard's Avatar
well when u sway a z6 head on an a6, you have to have the right cam gearor the right adj one. I had 2 diff adj ones for mine, 1 I had to have the gear at 4.75* for the belt to go on, the other it would go on with it set at 0*
Old Aug 7, 2013 | 08:31 AM
24TEN's Avatar
PHANTOM MENACE
^Mini-me = 1.5 non VTEC block + Z6/Y8 VTEC head, all else is really just a VTEC conversion. Just saying that there is a difference to avoid confusion...which is where this is going.
Having said that, timing becomes an issue in two scenarios:
A) when you use a 1.5 block because of the difference in deck height.
B) somehow you have a newer camgear on the older camshaft or vice versa because they are clocked a half tooth different (4.75 degrees? I don't recall off the top of my head)
The coincidence is that when using a 1.5 block it results in being a half tooth off so the simple solution is to use the newer Y8 camgear if using a Z6 head or the older A6/Z6/B7/B8/B2 etc camgear if using a Y8 head (yes ALL 88-95 use the same PM3B camgear).
Old Aug 7, 2013 | 08:45 AM
Fliptard's Avatar
I'm not sure, there is so many diff options on cam gears and timing. I gave up on mine atm, my compression is wayyy bad. So i'm finishing up my GSR in my ek and will mess with the sohc later.
bobbyx0r
Jul 30, 2011 11:47 AM
BlackHonda
May 9, 2007 12:24 PM
Red_ED8
Oct 10, 2005 10:58 AM
Trak_Day
Nov 21, 2003 05:12 AM
