B16 Help...
http://www.hmotorsonline.com/shop/sc...0Change%20Over
I saw this online, what else would i need to put that setup into a 1991 honda civic crx HF?
The only thing I can see are the motor mounts, anything else?
Thanks
Thanks
make sure that the axles and halfshaft along with the other parts included are the ones you'll need to make this fit your car...Besides that, you're right with just the motormounts...oh yeah, and dont forget the rear bracket that goes with the mount. Run a search for more info or check out http://www.hasport.com
the hf motor is already a MPFI motor so you wont need to deal with that much wiring. to make it easy I suggest the hasport wiring kit.
here is the complete list off the top of my head
motor mounts (HCP or HASport stay away from place racing)
shift linkage (the SIR linkage will not fit well)
(comes with the HCP kit or can be purchased seperatly from hasport)
HASport SIR wiring harness
you might need 90-91 integra axles. (setup varies depending on tranny type)
Del Sol Radiator hoses.
90-91 integra throttle cable.
there are some other randoms that you will prolly need as you go along
but for the most part I think thats everything.
it is also wise to do all matience on the motor before it goes into the car
ex: timing belt, water pump, cap rotor, plugs, plug wires, ect ect.
[Modified by crxconnection, 11:45 AM 10/25/2002]
if you buy the whole front clip.. the motor mounts still won't work.. JDM chassis have slightly different mount location.
if you buy that "complete swap" from hmotorsonline.. you will need:
mount kit (hasport is best)
shift linkage
throttle cable from 90-93 integra
clutch cable 90-93 integra
either buy a hasport wire harness for vtec.. or make one .. pretty easy if you know how to solder.
some radiator hoses
buy the mounts and shift linkage from Hmotorsonline
i probably left some stuff out.
go to http://www.hasport.com and look at the tech section.. they have pics and parts list for the swap.. good luck
shift linkage
some radiator hoses
1997 gsr
19
Apr 20, 2009 10:41 AM
iamhollywood[BRS]
Dec 16, 2003 10:26 AM
drevinder
Aug 27, 2003 04:15 PM
