92 accord fuel pump still shutting off. No power from pump.
Old Aug 6, 2013 | 05:18 PM
Dobird78's Avatar
Default 92 accord fuel pump still shutting off. No power from pump.
My 92 accord keeps shutting off on me. has new main relay. I've tested the voltage at the relay and harness at the pump when it shuts off and nothing. I've tested the injectors while cranking with a light tester, and they pulsate like their supposed to. I have spark but no fuel. mainly does it in the heat. Can anyone help me with this. I've been down for three weeks now.
Old Aug 6, 2013 | 05:24 PM
NZXTInerTia's Avatar
Default Re: 92 accord fuel pump still shutting off. No power from pump.
So you are or are not getting power at the pump? Your fuel filter is probably clogged if not the fuel filter is just plain broken.
Old Aug 6, 2013 | 05:50 PM
Dobird78's Avatar
the filter has only been in for about 4 months and it will run fine but then stumbles and shuts off. it just completely shuts the power off to the pump.
Old Aug 6, 2013 | 06:25 PM
Are you sure its killing the pump? Could be a clogged cat, or perhaps even a bad oxygen sensor.
Old Oct 9, 2013 | 05:51 PM
Dobird78's Avatar
Turned out to be the screen filter on the fuel pump
logjammin
17
Jul 29, 2013 07:59 AM
Motoxxxracer096
Aug 23, 2009 09:11 PM
nsone
May 14, 2009 04:35 AM
trooper0641
Nov 10, 2004 11:01 AM
2000_Civic_Si
Feb 8, 2002 04:13 PM
