help! f22b2 steady oil leak.
Old Aug 6, 2013 | 03:05 PM
swappedefloveit's Avatar
Default help! f22b2 steady oil leak.
Hello I have a 97 accord. It has a steady oil leak looks like it is c oming from around the filter. II just changed the oil and installed new filter and it is still leaking. I dont have a jack to get underneath to see for sure what the issue is. Any ideas?
Old Aug 6, 2013 | 05:07 PM
NZXTInerTia's Avatar
Default Re: help! f22b2 steady oil leak.
Originally Posted by swappedefloveit
Any ideas?
Google search for common Accord LX/DX oil leaks?
Old Aug 6, 2013 | 05:10 PM
m_shake's Avatar
If it has a oil cooler, it's probably the o-ring behind that, common failure. And if you don't know what or where the oil cooler is, it's what the filter screws on to.
Old Aug 6, 2013 | 05:13 PM
None of the F series motors came equipped with OEM oil coolers.
Old Aug 7, 2013 | 02:58 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
only you can find where the oil leak is coming from, we can only give you places where it might be leaking from.
idk how those engines are set up, but if its leaking from the filter and its not the filter, then ill have to be something above the filter that's dripping on it and going down around it.
youll have to visually inspect it to see where its coming from.
are the oil pressure sensors above the filters on those engines?
Old Aug 7, 2013 | 04:03 AM
holmesnmanny's Avatar
technically the f22a6 is the only f series accord/prelude motor to have an oil cooler
Old Aug 7, 2013 | 05:57 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Could be oil pressure switch, located above the filter.
Old Aug 9, 2013 | 06:50 AM
It was the pressure switch. Thanks guys. Cheap easy fix. No oil cooler on this model.
Old Aug 12, 2013 | 03:06 PM
Shit Posts: 15
10 Year Member
cool, anytime.
joelmatt89
Jul 16, 2011 01:30 PM
chiaxi2002
Apr 9, 2010 08:56 PM
holmesnmanny
Dec 10, 2009 03:14 AM
LOL@hondas
Jan 12, 2009 12:18 PM
TuningHonda
Feb 26, 2008 12:56 PM
