Missing TPS connector
Old Aug 6, 2013 | 02:45 PM
EJ6Coupe92's Avatar
Icon6 Missing TPS connector
So I bought my civic in October of last year it had a b18b1 from a 98 Integra swapped into it, but it was far from perfect. anyways..I was just wondering if anyone knows where I could find a tps connector and if there's s DIY on how to wire it up myself.
Thanks in advance.
Old Aug 6, 2013 | 03:03 PM
black97civic's Avatar
Default Re: Missing TPS connector
Best place would be a junkyard or search online for one. I think most civics have te same connector. I know at least the civic ex and any integra. As for wiring, is the old connector hooked up to the wires stil or is it missing? If its wired in still just cut the wires and butt connect the new one on the same way the old one was. It's better to solder and shrinkwrap though if you know how.
Old Aug 6, 2013 | 03:13 PM
EJ6Coupe92's Avatar
There's alot of cut wires...it probably doesn't help that I don't know what car that harness is from..but its 98 integra ECM so i'm assuming it's a 98 integra harness..I can't find anywhere what color the wires for the plug are.
Ive searched two junkyards, no luck.
Old Aug 6, 2013 | 03:14 PM
doublezerohatch's Avatar
Find the ecu pinouts for your car and wire it to the ecu . .
Old Aug 6, 2013 | 03:35 PM
EJ6Coupe92's Avatar
I don't have the connector, though..
Old Aug 6, 2013 | 03:48 PM
B_Swapped93's Avatar
You can take the TPS OR MAP plugs from any 94-01 integra or any 92-00 Civic....just match up the wires and twist them tighter or solder them.
Old Aug 6, 2013 | 03:52 PM
well that's the problem lol you need the connector. you could check craigslist or kijiji in your area for some one parting out a civic. You could go to your local auto wreckers and get one. consider going to Honda and buying one. and then get the proper Ecu pinouts for your ECU and wire it up. Google images for the pinouts you be laughing.
pretty sure that a lot of the Honda TPS sensors have the same plug. (im almost positive that nearly all civics have the same TPS plug . . . for our generation and before, some after . . . but its just heresay in my head)
Old Aug 6, 2013 | 04:38 PM
EJ6Coupe92's Avatar
I found a plug on ebay, and I found the pinout map for my ecu. but, there's only 2 wires coming out of my ecu for the TPS but, three wires on the plug..am I missing something?
Old Aug 7, 2013 | 01:34 AM
HondaPartsHero's Avatar
Technical Hero
there should be one wire for voltage (input), signal voltage(output), and ground. Most of the time the sensors share ground and voltage and the signal voltage is a separate wire. What pinouts are you looking at?
chevy383
Dec 31, 2013 08:35 PM
crxd88
Aug 4, 2008 04:17 PM
tilt
Sep 28, 2005 03:30 PM
