1997 Acura CL 2.2L VTEC, Where is this part?
Old Aug 6, 2013 | 02:44 PM
AcuraCl2.2L's Avatar
Default 1997 Acura CL 2.2L VTEC, Where is this part?
I am going to be replacing the crankshaft position sensor on my 97 Acura CL. Where is it? Does it go behind the crank pully or is run off the distributor?
Thanks guys
Old Aug 6, 2013 | 03:31 PM
holmesnmanny's Avatar
Default Re: 1997 Acura CL 2.2L VTEC, Where is this part?
It's located at the oil pump housing.
Old Aug 6, 2013 | 05:16 PM
NZXTInerTia's Avatar
Behind the crank pulley, mounted on the oil pump like holmesnmanny said.
Old Aug 7, 2013 | 11:14 AM
Can this be changed at home ??What tools are needed?
Old Aug 7, 2013 | 04:11 PM
I just installed an entire motor, belt job, transmission, and replaced a clutch in my Lancer. Anything can be done at home with the correct knowledge and know how. Just search it.
phaphon
Mar 27, 2012 07:17 PM
061000rr
May 28, 2009 12:25 PM
eJ6DM
Oct 18, 2006 08:39 PM
92civeg
Feb 26, 2006 09:47 PM
92civeg
Jan 15, 2006 09:12 AM
