cooling fan
1990 honda accord LX. The cooling fan does not run with engine running, but when engine is hot and with engine turned off the fan runs for a little bit.Not sure if this is normal of electric fans or something might be wrong.I already replaced fan switch.
Look for bad connections at the engine coolant temperature sensor (ECT) connector and if they're good replace the ECT. It should be sticking out of the thermostat housing.
Here is a troubleshooting chart
There are step by step procedures to test the fan control module, switches and relays in the PDF manuals found online.
rriznyk
Oct 18, 2015 08:25 AM
