Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 honda crv... spark fuel compression
Old Aug 6, 2013 | 11:37 AM
drb88's Avatar
Default 2000 honda crv... spark fuel compression
hey, honda crv....has spark, fuel, compression....three things that make a car run....it will not run, even tried a little starting fluid and would not fire...any ideas?
Old Aug 6, 2013 | 01:26 PM
ARMED's Avatar
Default Re: 2000 honda crv... spark fuel compression
what have you tried? how did the problem start? ignition coil?
you said its turning but it wont start? not trying to insult you but how did you check you spark and fuel? what was the compression across?
Old Aug 6, 2013 | 02:52 PM
blk1stgen's Avatar
if you have spark, fuel and compression it SHOULD run, unless it is electrically messed up somehow .
These are know for bad distributors, and they do have timing belts so ya never know
Old Aug 6, 2013 | 03:10 PM
LDForget's Avatar
timing belt could be in 2 parts. take the valve cover off. its 7 10mm nuts.
Old Aug 7, 2013 | 09:18 AM
vwtohonda's Avatar
Did you check multiple plugs for spark? I had a similar issue, but only pulled 1 plug. It had spark, had to tow it to dealership. Upon inspection it was the distributor cap and rotor, the screw came loose and ended up tearing apart the cap and button. After replacing those parts it ran like new. Just my experience with a similar issue.
Old Aug 12, 2013 | 02:55 AM
drb88's Avatar
checked fuel pressure, checked each wire coming from the dist. cap for spark, checked the timing belt, everything is good all across...still no idea..fuses are all good...
Old Aug 12, 2013 | 02:18 PM
blk1stgen's Avatar
try checking the main relay to the PGM-FI.
check that it's clicking when you turn the key on. or better yet find the power wire to the computer and see if you got power
Jos3ph
Nov 13, 2008 04:35 PM
SimplyTron
Feb 19, 2007 12:08 PM
knomexx
Jul 14, 2005 08:13 AM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
g2turbo
Sep 17, 2003 08:31 PM
