H22a
Old Aug 5, 2013 | 09:07 PM
sheist42's Avatar
Icon2 H22a
I'm doing a 94 and 02 accord coupe project at the same time and I learn quick but am a newbie at the car mechanics some one told me to put a k24 short block on the 02 idk what that means and I was told by the same friend I sahiuld look into a h22a for the 84 what's that mean and how can i do all of this? If anyone had any better ideas or suggestions I'm a 05 year old in a kindergarten class I'm open to ALL knowledge relates to this topic or not so suggest at will but keep in mind ill b asking for elaboration... Lol thank you kindly
I LOVE MY ACCORDS
Old Aug 5, 2013 | 09:29 PM
GhostAccord's Avatar
Default Re: H22a
Well if you are a 05 year old. I think you should have your daddy take care of this for you. I highly doubt that you have the cash or the skills.
H22 swap into a 94 is a very common and very well documented swap. Check out the Accord FAQ, look under the swap section. Being spoon feed is no way to learn anything!
Old Aug 12, 2013 | 12:09 AM
sheist42's Avatar
Default Re: H22a
It's cool buddy ur right so what exactly is the point of these forums I thought it WAS to ask questions... I'm not being sarcastic its a serious question I am nu to the forum thing.... But anyways I'm just a welder I Tig mig n stick **** ill even oxyfuel if I must... But hey did u see what I did far as the 02 goes? I did the short shifter and I posted it up I have to post all the pictures I have but haven't had time.... Just bought a civic coupe and ANOTHER accord coupe 02 just with no engine talked sum guy into giving it to me if I weld his engine that he cracked for his f150 so now I have ALOT of spare parts in the garage :-)
Old Aug 12, 2013 | 12:23 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: H22a
sheist42 most of what you need to know has been documented in the Accord FAQ. The F22 and H22 are of the same family, the biggest difference is due to the F series being a SOHC head and the H series being a DOHC head. First thing needed when doing the H22 swap into a F22 car are the engine mount and PS bracket as these are affected by the head type(SOHC vs DOHC). This is documented in the FAQ along with all the other idiosyncrasies of said swap, from wiring to exhaust.
K series is a bit trickier as this is a different engine family, and rotates opposite of the F/H engines. F/H engines rotate counter-clockwise, and K series rotate clockwise. F/H engines are located on the Left side of the car, where the K series is located on the Right side of the car.
Old Aug 12, 2013 | 12:44 AM
Mishako129's Avatar
Default Re: H22a
So that means the trans for the K series is on the other side? I was wondering why the new Civic had it that way. Why do you think they changed it?
I was thinking about doing the H22 swap cause it sounds like such a cool thing to have in a wagon; however my rebuilt F22 is running great. It would be cool to have more power. I thought about turbo but my engine is cast pistons and I want it to be reliable, turbo sounds like too much work and money. I would like to know if the H22 is similar to having a turbo and is worth it over a stockish F22? H22 swap sounds like a really fun project.
EDIT:
Or would the F22B DOHC engine be comparable to the H22? Cause I can find an F22B DOHC for the low.
Old Aug 12, 2013 | 09:10 AM
NZXTInerTia's Avatar
Default Re: H22a
EDIT:
An H22 is more expensive to build and feels absolutely nothing like a turbo. H's are also 10x more popular making the prices of parts higher than those of the F22's. You really need to drive (or, actually not) a boosted car, you obviously have no idea what it really feels like which is why you compare it to things all the time.
Old Aug 12, 2013 | 09:42 AM
Mishako129's Avatar
Default Re: H22a
Your talking turbo vs NA of course there is a difference in feel but what I meant was overall power and acceleration.
Not that you really need to build an H22 but bolt on's will work very well and if you want more kick get an ECU tune. For the low PSI you are running on your turbo a healthy H22 would do the same and even more... Plus reliable power.
Old Aug 12, 2013 | 05:10 PM
Default Re: H22a
An N/A H22A with bolt-ons will never touch a boosted F22. What trim are you running for your low PSI turbo build? You could be pushing anywhere from 250-350whp. Nothing unreliable about a properly built boosted F22. I love N/A but dollar/hp, boost wins and it is just as reliable and more than likely more economical.
Old Aug 12, 2013 | 05:13 PM
Mishako129's Avatar
Default Re: H22a
Okay, I got ya. The reason i'm asking is there this JDM H22 for sale in my area for $300. Only thing is the guy said the top end may have gotten lack of oil cause the guy who installed the oil pump messed up...
Either way what do you think? It has all the parts there and looks like a great deal,
Old Aug 13, 2013 | 12:13 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: H22a
Busted engines are only worth their money as a core. Don't care if it was a blown hayabusa time attack world title butt hole hurter, broken parts are broken parts.
Link doesn't work.
If it is a complete engine swap with all the bits needed to bolt into an Accord without having to buy anything more, mounts, intake/exhaust, wiring/ecu, etc. Then the $300 would be cheap. But if it is merely a busted H22 long block, it is only worth core/scrap value.
Old Aug 13, 2013 | 01:37 PM
Mishako129's Avatar
Default Re: H22a
Link doesn't work.
Yeah scrap value but how much is that? You could easily get $100 for the IM, $200 for the Head, $100 for the block, so that's already $400 right there.
So even in scrap this motor is worth it.
But you're speaking of cheap deals, $300 for a damaged engine is not a cheap deal. Its a decent deal I suppose.
Old Aug 13, 2013 | 06:06 PM
Default Re: H22a
You will absolutely not get $400 in scrap aluminum. I work at a body shop, and we scrap/junk aluminum and steel CONSTANTLY from totaled cars. Unless Alum and steel are doing damn good in your area.
In the end it all depends on what is really wrong with the motor. Now lets stop posting on THIS OP's thread, at least not about your stuff.
Old Aug 13, 2013 | 06:11 PM
Mishako129's Avatar
Default Re: H22a
I didn't mean scrap I meant junk parts like used parts that people wanna buy.
Yeah $400 is about right for selling the parts for use, maybe even more.
Sorry its about H22's and I didn't wanna make another thread.
H22's are Honda gold and their parts are worth a lot to people.
Old Aug 13, 2013 | 06:53 PM
Default Re: H22a
Burnt out parts from a broken engine aren't worth shyte, H22 or not!
The only way you would get any money for parts out of that engine. Would be if you lied and didn't tell people that the parts came out of an oil starved, non running engine! Lying is not a good way to do business or live life!
Old Aug 13, 2013 | 07:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: H22a
If it were worth anything the fellow would have had scrapper/machine shop pick it up.
~30 for the block
~15 for the head
~10 bucks for the bits.
Broken engines are only worth their weight in scrap prices. Don't talk yourself into spending money on a busted engine.
It is not a deal at all.
Old Aug 13, 2013 | 08:01 PM
Default Re: H22a
The only good deal on a broken engine is when they offer to pay you to take it off their hands. That or take it for free. Like I did with my F22A6, the block had a rod thrown right through the side of it. Guy said come take it! So I went and looked it over, the head was like new. So I took the complete engine that night free of charge!
All I was looking for was the head anyway. After tear down and inspection found it to be in great shape. No signs of any abnormal wear. The block has since been retired to the scrap yard.
Old Aug 13, 2013 | 08:41 PM
Mishako129's Avatar
Default Re: H22a
All I needed was the head and it was in immaculate shape. No signs of any abnormal wear. The block has since been retired to the scrap yard.
Dang I guess you're right. On ebay though you can sell engine parts for much more than craigslist, even if they are damaged. Depends on what it is, like an F22B DOHC cylinder head is going to sell for a very high price simply because it is a rarity. The H22 cylinder head would be no different, they're in high demand. Ebay is good because it gets such a broad range of viewers who are willing to pay a lot for parts.
For instance, I sold an F22a cam the other week on ebay for $109... I payed $20 to ship it.
Old Aug 13, 2013 | 10:05 PM
Default Re: H22a
Old Nov 25, 2013 | 03:03 PM
sheist42's Avatar
Default Re: H22a
Ok so this thread took a left turn but its cool idk the forum IS for socializing so POST AWAY... Buton a good note the accord with no engine turned into a accord with a j series v6 so I been slowly taken that apart for parts for the other accord and, I'm 90% sure ima,put that into the civic... ;-) Lifes good....
Old Nov 25, 2013 | 03:07 PM
Zak325's Avatar
Default Re: H22a
For being a "newbie in car mechanics" your swappin these engines like it's nobody's business, haha. Good luck. Maybe I'll see you around when I finish my car
Old Nov 26, 2013 | 04:36 AM
ej7attack's Avatar
Default Re: H22a
what you putting in civic? j series? f/h series? k?
Mikzize
Feb 1, 2014 07:33 AM
rayrayh22a
Jun 15, 2008 08:46 PM
Auto96accord
Aug 13, 2006 04:40 PM
94 accord h22a
Aug 14, 2005 02:31 PM
SpurtlesAccord
Feb 16, 2005 06:00 PM
