Gates Timing Belts
Old Aug 5, 2013 | 05:46 AM
Fitz Williams's Avatar
10 Year Member
Default Gates Timing Belts
Gates lists two timing belts for the F22B1, the T244 and the T244RB. The T244RB is listed as a high performance belt and sells for $106 from Rock Auto while the regular belt is $20. Is the T244RB worth the difference, or more to the point, what is the difference?
Old Aug 5, 2013 | 07:49 AM
djkurious's Avatar
Default Re: Gates Timing Belts
Subscribed! I also wondered that also.
Old Aug 5, 2013 | 07:19 PM
GhostAccord's Avatar
T422 is the OE replacement. It's a basic rubber and nylon fiber construction belt.
The RB or racing belt is constructed using different materials.
Originally Posted by www.gatesracingproducts.com
Gates Racing Timing Belts are 3x Stronger and 3x more Heat Resistant than Stock Belts. High Saturation HNBR Elastomeric Composites Assist with Exceptional Durability and Heat Resistance. Reinforced Tooth Jacket Provides Extra Wear Resistance, Doubling Tooth Strength. High Strength Glass Cords Further Increase Durability.
Now on to the question, is the RB worth the difference? It would be if you are running higher rpm, consistently running hotter engine temps and beating on the engine. Might be a good choice if you're not running a timing belt cover as well. Other than that I wouldn't bother spending the extra $86.
Old Aug 6, 2013 | 04:08 AM
10 Year Member
Thanks. That is what I thought might be the case. If it gave extended intervals between changes it might be worth the money. But since I don't have 400 hp or run 30 lbs of boost I guess I will go with the T244.
Old Aug 6, 2013 | 08:41 AM
Lost Again's Avatar
Get the whole kit? TCKWP244....
Old Aug 6, 2013 | 08:54 AM
10 Year Member
Sure. Just wondering about the belts. I would still like to have the HD one, but I guess that doesn't make much sense for my car.
1990IntegraLS
Dec 17, 2016 04:30 PM
todenbach
Jan 26, 2014 12:26 AM
Kellindal
Dec 1, 2007 02:20 PM
JDMtype Eg6
Feb 18, 2007 05:45 AM
