Rad support bolt on Q
Old Aug 4, 2013 | 03:22 PM
BlackCivicEX's Avatar
Icon2 Rad support bolt on Q
Hey guys, Have a question about bolting on the top part of the rad support.
My car was hit a couple years ago on driver side slightly, bent in the upper rad support and never was the same since and had a slant to the headlight.
If i was able to just re attach the upper portion of the support by bolting it up near the fender bolts, and creating a bracket from the bottom to the upper support ( peice beside the rad ) should i be fine with this ?
- not my car - upper rad support
- middle piece -
Thoughts/ comments / why or why not.. Welcomed. Thanks
Old Aug 4, 2013 | 03:24 PM
jbpnoman's Avatar
Default Re: Rad support bolt on Q
I'm not sure I can make sense of what you're saying, but the radiator support is not a "bolt in" part. It requires welding.
Old Aug 4, 2013 | 04:39 PM
My apoligies on that...
The upper part where the hoodlatch is on.. I was going to break the welds off on the sides and bolt a new (upper support) where the headlights bolt onto.
And going to create a new support from the lower to upper bar (pic 2) which is beside the radiator.
if that makes sense
Sycodc5
Apr 8, 2015 11:03 AM
FormulaIntegra
Nov 4, 2009 12:00 PM
ForestGreenCiv
Paint and Body
15
Nov 23, 2008 07:41 PM
b18-c-rx
Dec 20, 2004 05:20 PM
