Help SRS 5-2 code on 2005 civic lx
I was having the same issue as some others were having. My Honda civic 2005 LX automatic has its airbag light on for a couple of weeks. I first tried to reset it but was unsuccessful so I checked the battery and it was bad. So after I changed the battery the light was still on. I tried to reset it using the paper clip method but still same. I found out the code was 5-2 (internal failure of SRS unit). So I decided to change the SRS unit and changed it but the light never came off. I also tried changing the instrument panel just if that helps but still same. Then I found out that the alternator might cause srs code but when it was checked the alternator was fine (14.4 volt with ignition on). The code is 5-2. Anyone has any idea? The Honda dealers couldn't figure it out so they say they need to replace the entire front for $2000 + labor. That is expensive. If anyone has any idea help please.
Thanks.
Thanks.
An SRS light can also be caused by dirty contacts for the switch on the driver's seat belt buckle. I took mine apart weeks ago to clean it, causing the light to go away. Months later, the issue came back. This time, the cause is unknown.
deanwashere
Jul 25, 2018 04:28 AM
mrtimepa
Jun 21, 2013 05:41 AM
villaninblack
May 20, 2009 10:08 PM
