timing belt
Old Aug 3, 2013 | 06:21 PM
giovannie23's Avatar
Default timing belt
My camshaft tdc marks and crankshaft tdc marks do not line up how do I get them realigned ? Thanks in advice
Old Aug 3, 2013 | 06:28 PM
Jmb106jr's Avatar
Default Re: timing belt
go to the FAQ its a sticky a the top of the page there is a great diy there with pics and all the info you need.
Old Aug 3, 2013 | 06:56 PM
Yea I read it but not really sure exactly how u align them if there off..I took off the timing belt from the cam by loosening the tensioner but I'm not removing the entire timing belt
Old Aug 4, 2013 | 01:17 AM
holmesnmanny's Avatar
if the only thing you did was to remove the belt from the cam then you should be able to get it to line up again without pulling the entire belt....but if you can't then you're going to need to pull the entire belt and redo it but i think you knew that already...do it the right way and don't be lazy about it
Old Aug 4, 2013 | 07:29 AM
That sucks ..is it possible to rotate the crank pulley to tdc with the belt off the cam then when I got the crank lined up I can slide the belt back on the cam so there both at tdc?
Old Aug 4, 2013 | 07:13 PM
Anybody
Old Aug 4, 2013 | 07:20 PM
10psiLsEf2's Avatar
Dont take short cuts on your timing bro you'll. Regret it. Just cause your having truble with crank pulley bolt doesnt mean you shoulsnt try harder
Old Aug 4, 2013 | 08:05 PM
That's true man thanks for all the replies
Old Aug 5, 2013 | 01:06 AM
DCRB's Avatar
here's how i got my crank pulley bolt out on my old cb7 rust bucket (RIP)
1: i soaked the bolt with pb blaster for a good week
2: ended up jacking the car up high enought that i could get under it freely
3: using a chain wrench (the honda tool would work well for this too) i locked the crank in place physically
4: i put a short 17mm 1/2" socket on my ratchet, grabbed my core support with my hands and used my whole body weight to force the crank pulley bolt to break free.
this is after trying to use a breaker bar, electric impact gun, extensions would just flex and twist... the shop that did the timing belt before must have used like 300psi to torque that sob on
Old Aug 9, 2013 | 08:30 PM
Koo imma try that before getting some breaker bars hopefully I can get it I had a shop change my timing belt about a year ago imma find out how much they torqued it the heads grtting resurfaced right now imma start putti mg it back together sunday
gravity73
Feb 9, 2014 03:05 PM
eracer08
Jun 1, 2013 07:23 AM
b00st Junkie
Jul 24, 2010 07:29 PM
eg6d15
Jan 7, 2008 01:21 PM
7andaswitchblade
Jun 1, 2007 01:46 PM
