Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch stays engaged all the time
Old Aug 3, 2013 | 07:30 AM
nismosalamander's Avatar
Default clutch stays engaged all the time
94 gsr y80 replace clutch,clutch master,slave cylinder and bleed system and still engaged. there is no free play on the fork. i try to push the slave back and its not moving. need help
Old Aug 8, 2013 | 06:58 PM
m90polk1's Avatar
Default Re: clutch stays engaged all the time
So does the slave cylinder pin slide at all when you depress the clutch pedal. If no movement then check the system for air still in the lines. Other than that i would recheck the clutch fork and make sure its propeely installed.
xxgriffonxx2
Apr 28, 2010 10:18 AM
niceprelude
33
Dec 20, 2008 04:56 AM
Perfourmance
Nov 16, 2004 11:08 AM
FLCivic
Jun 30, 2004 03:48 PM
stRtypR25
Jan 21, 2003 08:45 PM
