bogging issue on d16z6
I got stock d16z6 with dc header intake and exhaust and just got an adjustable obx cam gear and this dude at my work installed it and advamced it 4degrees...the issue im having is when im at dead stop and go to rolloutta 1st it bogs up til about 2000 rpm then its good after that...only bogs at take off from dead stop
If u did not have this issue before the obx cam gear install then you would think that its timing that is not right, I would adjust cam gear or distributor or both to see where it runs best, just my 2 cents
Don't let him near your car ! lol you don't just advance it 4 degrees with out knowing WHAT you're doing and the affects it will have. this is a simple fix put the stock one back there's no need for an adjustable gear in your case. OR set this one correctly !
roberts
Mar 12, 2006 01:22 PM
