B18c rebuild?
Old Aug 2, 2013 | 01:04 AM
FlashfmDB8's Avatar
Icon2 B18c rebuild?
What parts need a swap when rebuilding the engine? what are parts that can be re-used?
Old Aug 2, 2013 | 04:26 AM
jdmjunkieXL's Avatar
Default Re: B18c rebuild?
Ahhhhh headers???? Whhhaa u talkin bout???? The head foo?? Its all upto you and your wallet
Old Aug 2, 2013 | 10:41 AM
FlashfmDB8's Avatar
Old Aug 2, 2013 | 10:48 AM
94eg!'s Avatar
#1 Super Guy
Loved
Provided the Cylinders & Pistons check out, REPLACE:
- rod bearings ($10ea x8)
- main bearings ($10ea x10)
- thrust bearings ($11)
- piston rings (must hone cylinders 1st) ($30ea x4)
- all gaskets & o-rings (~$120)
- water pump ($85)
- timing belt ($40)
- tensioner bearing ($65)
- thermostat ($18)
- crank seals f&r ($21)
- cam seals f&r ($19)
- valve stem seals ($18)
Reuse:
- everything else?
Roughly $700 in parts (OEM online pricing) plus the cost of a simple re-hone.
If you need new pistons ($200), consider an expensive hone job.....or a bore & hone w/ oversized pistons if the cylinders are screwy. I have no idea how much that costs.
Old Aug 2, 2013 | 12:05 PM
racebum's Avatar
hone has to be incredibly fine if you want to avoid having an oil burner. lot of guys have had success with 400-600grit hones
Old Aug 2, 2013 | 04:03 PM
R-Spec Ferio's Avatar
oil pump is something I would never re-use imo. USDM R-spec oil pump is $130 plus the lower timing cover would have to be replaced with the domestic style cover since you have a JDM motor AND THEY ARE DIFFERENT. another $60. or the genuine JDM oil pump is around $200. NO DIFFERENCE IN PERFORMANCE.
Old Aug 2, 2013 | 05:35 PM
racebum's Avatar
also would want the usdm crank sprocket since the jdm and usdm use different timing markers
Old Aug 2, 2013 | 06:39 PM
op why did u edit the original post??? i hope ur having someone else build this... Cuz if u dont kno the difference between head and headers i would be scared
Old Aug 2, 2013 | 07:57 PM
94eg!'s Avatar
#1 Super Guy
Loved
I'm pretty sure the 96-97 JDM R motor uses the OBD1 oil pump from the B16A. You can buy them in the US on the 94-95 Del Sol VTEC. 15100-PR4-A03 If you go with the OBD2 pump, you need to change the lower timing cover & rubber seals.
Old Aug 3, 2013 | 01:09 AM
R-geek-c5's Avatar
[QUOTE=94eg!;49023523]Provided the Cylinders & Pistons check out, REPLACE:
- water pump ($85)
- timing belt ($40)
- thermostat ($18)
Reuse:
- everything else?
If you need new pistons ($200), consider an expensive hone job.....or a bore & hone w/ oversized pistons if the cylinders are screwy. I have no idea how much that costs.[/
QUOTE]
Just to add to this list... ARP bolts in everything you can put them in. And if you reuse the connecting rod's have them checked by your machinest, and machined if needed. Good luck with your build.
Old Aug 3, 2013 | 01:35 AM
Runnerdown's Avatar
If the bearings look great, I have no issue with reusing them. Same with the oil pump, many times people are quick to discard these items with no wear! These will not fail if they are simply "old". In my opinion the key elements in a b18c rebuild are the following:
- Pistons and rings with OE .25mm oversize
- Cylinder head! This is usually overlooked! I'm not an advocate of reusing 13-18 year old valve springs. Exhaust valves at a minimum should be replaced. Valve guides are usually ok but some shops do more harm than good by replacing them.
- Obviously seals, gaskets, timing belt etc should be replaced. Thermostat is important too. Oem parts are high quality and aftermarket stuff should be avoided in this department.
Old Aug 3, 2013 | 03:00 PM
racebum's Avatar
could be. the jdm pump uses a different marker location from the obd2 crank sprocket. would have to try the obd1 gear and see if it lines up
really makes sense though. honda wouldn't likely design a whole new part and only did so with obd2 for the cfs
Old Aug 3, 2013 | 03:01 PM
racebum's Avatar
same with exhaust valves. they get brittle after that many heat cycles
Old Aug 3, 2013 | 08:06 PM
I kept my JDM lower before I had my rebuild. ill take a pic. I also have a B18C5 OEM oil pump BNIB(don't ask why). ill take some pics.
Old Aug 3, 2013 | 08:20 PM
R-geek-c5's Avatar
There are only two designs of b series oil pump. Just to end that debate. There's the obd1 and obd2. Most people talk about having a type r oil pump, but in all actuality they have only upgraded to an obd2 pump.
Old Aug 4, 2013 | 08:18 PM
racebum's Avatar
there are two different part numbers for non vtec and vtec
all we were curious about is if the jdm pumps are nothing more than an obd1 pump. you would think they would be but i never checked one when i was into these cars
Old Aug 6, 2013 | 01:14 AM
R-geek-c5's Avatar
Sorry, meant to say with the vtec pumps. But yes the JDM pumps are just obd1's.
Old Aug 6, 2013 | 04:03 AM
this is true. didn't know it and asked some questions and it is verified. my b16b had the obd1 style and it was switched to the later one at rebuild time. new timing cover eats up the cost savings of switching to the obd2. about $200 for the obd1 and $130obd2+$60 for new cover. always thought there was a difference with a type r pump and a standard vtec pump. oops.
Old Aug 6, 2013 | 05:40 AM
94eg!'s Avatar
#1 Super Guy
Loved
OBD1 VTEC pump 15100-PR4-A03 is $154 at OEMAcuraParts.com
hayden55
Jun 16, 2016 02:51 PM
type_r_ek
Jul 30, 2012 06:33 PM
r01516
Sep 4, 2008 02:33 PM
ej1252
Jul 2, 2008 09:10 PM
Evolsport
Dec 5, 2002 01:04 PM
