For the boosted H22's.....
Old Oct 24, 2002 | 11:32 PM
H22Prelude's Avatar
Default For the boosted H22's.....
What compression, kind of sleeve, kind of piston, how many pounds of boost are you guys running, and how long has it lasted? I'm just trying to ge some ideas...
Old Oct 24, 2002 | 11:36 PM
PrecisionH23a's Avatar
Default Re: For the boosted H22's..... (H22Prelude)
I dont have a h22a, but ill give you some advice. The H series ringlands are weak and they are the first thing that tend to go to hell while boosting our motors. I do not recommend boosting above 8psi on a properly tuned stock motor. On my h23a setup i run darton sleeves, JE 9:1 pistons and i run 15psi of boost right now. Ive been running it for 1500 miles with zero problems since i had it dyno tuned.
Old Oct 25, 2002 | 05:48 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: For the boosted H22's..... (GudeH23a)
i've got golden eagle sleeves and je 10:1 compresion pistons, and i plan to be seeing about 12psi daily. with proper tuning, i SHOULD have zero problems
Old Oct 25, 2002 | 05:52 AM
satan_srv's Avatar
Default Re: For the boosted H22's..... (Boosted97Lude)
So you went with 10:1? Hmm I'm trying to decide 9 vs. 10....I just don't want my performance to suck before I put the turbo on
Old Oct 25, 2002 | 06:01 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: For the boosted H22's..... (satan_srv)
ok, to be honest, the only reason i got 10 to begin with is b/c i was shipped the wrong ones, and i didn't reaslize this till after i had them balanced. but then after doing a little research, i realized that i would be better off with them, and it would still be perfectly safe for the engine. some kind of formula, if you drop the compression, yo uhave to run like 3.5 more lbs of boost to make up for it or something like that. besides that, with all the engine work i've got done, 10:1 should be just fine
Jason kiDD's Avatar
Hmmn nice info, but what other parts are you guys using.. Rings? Rods? What size pistons?? Was anything overbored?? Ya know **** like that..
I will probably go turbo in 2 years so any good info is useful... Maybe sooner if I get rich..
Old Oct 25, 2002 | 06:08 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: For the boosted H22's..... (Jason kiDD)
haha... ok man, you asked for it
H22A4 in my 97 Prelude, daily driven:
GE Sleeves, .25 over
Eagle Rods (balanced by VS Racing)
JE 10.0:1 Comp pistons (Balanced by VS Racing)
GE Intake Manifold (thanks Vince)
Prodrive Oil Pump gear
knife-edge and balanced crank by KMS ( http://www.honda-performance.com )
Moroso Oil Pan
KMS stage 2 head job
KMS stainless steel nitrided valves
Crower Stage 2T cams
Crower valve springs
Crower Titanium retainers
Dephi 84lb injectors (~860cc)
AEM high flow fuel rail
AEM FPR
Erick's Racing TB
NX Directport (eventually)
NX N-ter cooler kit (eventually)
GReddy based turbo kit (TD05/18G, eventually upgraded to a BB with bigger wheel, clipped, ported, etc)
GReddy FMIC
Greddy Type S BOV
Custom FMIC piping by Smith Family Tire in Hendersonville NC (he drives a mean RX-7)
Hondata s200 w/ datalogger
APEXi AVC-R
HKS Type 0 turbo timer
Walbro Fuel Pump
Quaife LSD
DSS stage 3 axels
gaskleppie
Jul 23, 2012 03:54 PM
Rob97'SH
Oct 17, 2009 05:14 PM
H22aAccord
Aug 2, 2004 08:45 PM
Fuzion
Sep 11, 2003 01:49 PM
blazin
Apr 3, 2003 09:38 AM
