Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
motor mount question
Old Jul 31, 2013 | 11:46 AM
Mike Husted's Avatar
Default motor mount question
Have an 01 em2 the front mount that's in front of the rad has a broken bolt. Does anyone know how to fix it and also what the size, pitch thread etc is on that bolt
Old Jul 31, 2013 | 06:36 PM
JJ291's Avatar
Default Re: motor mount question
I would try and place a jack under the oil pan with a piece of wood to protect the pan. Raise th engine and take the weight off the mount enough to get the bolt out and a new one in. I would buy the new bolt from Honda - it should have a lock tab on the nut so you only spin the bolt in and don't turn the nut. Can't remember but I want to say torque on the bolt was somewhere in the 40-50 ftlb range.
Also, I would put the new bolt in hand tight. Then start the car, put it in drive, then reverse, then drive again, then park. Then tighten the bolt. I did this when I replaced my mounts because my engine was vibrating a bit in reverse (on advice of a really cool Honda tech). It worked.
Old Aug 1, 2013 | 12:50 PM
How do I get the broken half out. I'm worried that if I drill it out it'll put a hole or some crap in the trans. I'm scared lol
Old Aug 1, 2013 | 02:06 PM
JJ291's Avatar
I'm not sure I understand why you would need to "drill it out". The bolt is loose in the actual mount - it should slide in and out. Are you talking about the bolt highlighted in this picture or the bolt that actually secures the mount to the engine?
Old Aug 1, 2013 | 02:26 PM
Noooo. Sorry. See part number 13. There's a bolt similar on the bottom that's broken. Not the cross bolt. It mounts the mount to the trans not the trans to the rad support
Old Aug 1, 2013 | 06:55 PM
JJ291's Avatar
Ouch. Just my opinion, but I would buy the Honda bolt, by the time you mess around trying to match it you can just buy one and what are we talking, a few bucks? I'm not a bolt extractor expert but here is where I would start. A method from our blokes in the UK. I'd hit it with some PB blaster first.
Old Aug 7, 2013 | 02:48 PM
DARDCR's Avatar
Just take your time and get a drill bit one size smaller and keep it lubed while drilling and drill it out. It is not a hard if you take your time. Make sure you get a new drill bill to start with.
Bob_760
May 17, 2007 10:37 PM
george34
13
Feb 22, 2006 11:09 AM
projectPSI
Jan 31, 2006 06:36 PM
red96
Oct 17, 2002 02:53 PM
