ECT Sensor Removal
I'm changing out the head gasket in a 98 Civic LX and, what I think is the ECT sensor (near the distributor) needs to come off before I pull the head. It appears to be wired straight into the wiring harness so I can't unplug it during removal. I don't want to twist the wire when I take it off, is there some trick to this?
It's the sensor with the single wire right next to the water return hose on the head, I discovered on closer inspection, that it's connected like a spark plug wire and pulls right off. Now if I can only get the lower O2 sensor plug to come apart, it's like it's super glued together. I haven't had any probs with any of the other connectors yet.
raider1qaz
Feb 13, 2013 12:14 PM
LSEGHATCH
17
Aug 14, 2005 08:47 AM
dropd4door
Dec 27, 2004 09:53 PM
forksports
10
Feb 7, 2004 03:55 PM
