smoking after wet compression
Old Jul 30, 2013 | 05:20 PM
sherrybogue's Avatar
Default smoking after wet compression
How long should my car smoke after wet compression test I have a 98 honda civic exams were would I find a diagram of the wiring structure for the 02s sensor from the sensor to were its power comes from
Old Jul 30, 2013 | 06:02 PM
volvo9's Avatar
Default Re: smoking after wet compression
Why, how long have you let it run for? Have you driven it (actually driven it, not around the block)?? You likely got oil inside of the exhaust, or even part of the cat, it will smoke for a while if you do not rag on it, or get it on a highway for a bit.
Get it on the highway and rev it out good, you'll be fine. I can't really see this causing damage.
What are you trying to diagnose with your o2 sensor? More info helps...
Old Jul 30, 2013 | 06:21 PM
B_Swapped93's Avatar
you put too much oil in lol not a big deal just drive it out not much you can do now.
AndrewHuffman
Sep 18, 2008 06:17 PM
98exowner
Sep 9, 2008 12:15 PM
VNTEC
May 22, 2004 08:23 PM
oneslowcivic
10
Nov 11, 2003 03:27 PM
