b18b1 is having trouble starting
so I have a 1992 civic hatch with a b18b1 swap but the thing is, is when I start it on a cold start it turns over like 10 times then I guess sputters then finally starts but then idles at like 300ish rpms. sometimes it will die out and I have to try and start it again. but then if I start it (when it finally starts) and let it run for 3-5 minutes the idle raises to about 800 rpm and drives completely normal. I have replaced:
starter
alternator (mine was dying so figured I would replace it)
new plugs with ngk
tps sensor
and ran some injector cleaner because I thought it could have been clogged injectors
its weird because I can hear the fuel pump prime then the main relay click so I know its most likely not a fuel problem, I am just worried when winter rolls around I might be screwed. I don't want to keep throwing money into it and have no improvement.
Any ideas would be great!
starter
new plugs with ngk
tps sensor
Nov 17, 2012 07:52 AM
Pwnmeister
Aug 2, 2011 12:41 PM
dizzyroc88
May 19, 2006 05:32 PM
