93 del sol si. Codes 3, 6, 7, 14, and 41
Old Jul 30, 2013 | 11:08 AM
cody_sandlin's Avatar
Default 93 del sol si. Codes 3, 6, 7, 14, and 41
On my del sol if u turn on the ac the idle drops to where it's barely running and if I give it has it limits it to about 2200 rpms. I changed the tps cleaned the throttle body and put on an ac tensioner pulley. I've tried loosening the ac pulley but nothing helps. Please help!!!!!
Old Jul 30, 2013 | 11:36 AM
Former User's Avatar
Default Re: 93 del sol si. Codes 3, 7, 14, and 41
Codes associated with recent work done? All stock Del Sol?
Do all codes return after ECU reset?
Old Jul 30, 2013 | 11:49 AM
It was just rebuilt about 6k miles ago and it's all stock. Ecu reset? Haven't tried it do I just unplug the battery for like 5 mins?
Old Jul 30, 2013 | 11:52 AM
Remove the 7.5A hood Back Up fuse for 3 minutes. Reinsert fuse.
Run engine for a minute. Recheck codes with engine still running.
Old Jul 30, 2013 | 11:53 AM
Ok I'll try it and tell u the results.
Old Feb 16, 2014 | 05:36 PM
Default d16z6 engine codes 6 7 and 14...help!
I have a 93 del sol si I just rebuilt and it's showing the codes 6 ,7 and 14. Runs pretty good but if I hit the gas like taking off it boggs down for a second but if I do it slowly it's fine and after afew mins of driving the temp gauge shoots to hot but the radiator is cold/normal. Any help or tips would be much appreciated!
Old Feb 16, 2014 | 06:17 PM
Default Re: 93 del sol si. Codes 3, 6, 7, 14, and 41
You are allowed one thread per topic. Related threads merged.
whoshawnj94
Jun 9, 2016 09:40 PM
DelTacoSi
Oct 30, 2013 06:30 PM
mcq_dolla
Feb 10, 2009 05:45 PM
