p28 limp mode no cel
Old Jul 30, 2013 | 12:33 AM
tempsohc's Avatar
Default p28 limp mode no cel
Alright lets start off with my car, I got a 99 civic sedan and swapped in an lsv. Im using a si distributor ,neptuned p28 ecu tuned. ive been using the same wire harness since I did the swap (2 years).
So now to my problem. Drove my car the night before perfectly fine, next morning car starts up fine idles fine no check engine light. On the way to the gas station noticed my car wouldn't pass 3000 rpm car would just bog. I have tried searching and have never found any answers to this considering I don't have a check engine I don't know where to start. I tried unplugging tps sensor(just to see if my cel light comes on and it does). changed my igniter that's about it.
Any ideas what it could be?
Old Jul 30, 2013 | 02:30 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: p28 limp mode no cel
I would check the spark plugs and/or spark plug wires. If it's not that, it has something to do with the ignition (distributor, rotor button, ignitor, etc.).
Old Jul 30, 2013 | 02:43 PM
tempsohc's Avatar
Is there any resistance spec for nology hot wires?
Old Jul 30, 2013 | 06:12 PM
Former User's Avatar
Replace the fuel filter, and do a full ignition system tune up while you're at it.
Old Jul 30, 2013 | 09:32 PM
tempsohc's Avatar
is there any testing procedures before replacing unnecessary components? plugs are 200 miles old and wires are about 1000 miles old
Old Jul 31, 2013 | 02:18 AM
NVturbo's Avatar
O.G. triple O.G.
NOLOGY wires are G A R B A G E. Replace them with NGKs and be done with.
Old Jul 31, 2013 | 12:00 PM
tempsohc's Avatar
Lol alright Ill try that and get back
Old Jul 31, 2013 | 10:46 PM
tempsohc's Avatar
alright so just changed my wires to some spare taylor wires I had, same thing 2 steps at 3000. don't have money for new wires right now. I guess ill try changing out my coil too when I get a chance
Old Jul 31, 2013 | 11:57 PM
Marvin1985's Avatar
You check to see if the cat is clogging up?
Old Aug 1, 2013 | 02:28 AM
tempsohc's Avatar
running a test pipe so I don't think that would be a cause
Old Aug 2, 2013 | 01:29 PM
tempsohc's Avatar
alright weirdest thing happened, went to go datalog the 3000rpm limit the moment I started datalogging and reved, car reved normally? disconnected the demon from my laptop car still reved normally, turn car off and back on and rev limits at 3000 again until I click start datalogging then it revs normal?
Old Aug 19, 2013 | 10:55 PM
tempsohc's Avatar
thanks everyone that tried helping, updated Neptune and the firmware cars running fine
mekal
Engine Management and Tuning
Jul 4, 2011 09:40 AM
chazfehn
12
Oct 3, 2008 03:27 PM
Everyones Hero
Mar 25, 2006 08:48 AM
h22teg
Mar 28, 2005 08:15 PM
