VTEC wiring/ecu
Old Jul 29, 2013 | 07:23 AM
CrackerJDM's Avatar
Default VTEC wiring/ecu
I am new here so if this post is in the wrong place I'm sorry. I have a 97 civic HX that had a D16y5 with VTEC and It blowed so I put a JDM D15B with a 3 stage VTEC ( dual VTEC silinoids) the new VTEC has 2 wires ( red one and a green one) but my harness only has a green one. I hooked green to green and left the red one unhooked but now my CEL is on for VTEC malfunction. Do I need to swap Ecu or harness or how can I get this to work?
Old Jul 29, 2013 | 07:39 AM
Fliptard's Avatar
Default Re: VTEC wiring/ecu
there is no such thing as vtec stages, the solenoid is either open or closed. Having more, a bigger opening for the oil or anything is pointless. Understand vtec. It locks in another set of rockers for a bigger-longer valve duration to give more power. There Is no way to alternate it besides getting a bigger cam.
Old Jul 29, 2013 | 12:23 PM
HondaPartsHero's Avatar
Technical Hero
You have to use the correct ecu, P2J
Old Jul 30, 2013 | 04:17 AM
CrackerJDM's Avatar
Thanks hondapartshero.
Old Jul 30, 2013 | 04:19 AM
CrackerJDM's Avatar
Fliptard this is for you... There is a 3 stage VTEC http://en.m.wikipedia.org/wiki/Honda_D_engine
Old Jul 30, 2013 | 04:28 AM
Fliptard's Avatar
hm, interesting. Learn something new everyday.
It's more for fuel economy that "vtec" but sure.
But yes, you are going to need the ecu for that motor. which is P2J, and a man or auto depending on which drivetrain you have. Or it won't run correctly.
Old Jul 31, 2013 | 12:57 PM
CrackerJDM's Avatar
Also my engine harness has just a green wire since it had a single VTEC silenoid, which harness had the red wire and the green wire to hook up the VTEC? And would I need a jumper harness to connect the Ecu?
Old Aug 1, 2013 | 04:14 AM
Fliptard's Avatar
what year and model is the car?
Fliptard's Avatar
nevermind, I can't read, haha what year is the engine?
Old Aug 4, 2013 | 11:04 AM
CrackerJDM's Avatar
Not sure it just says D15B and under it it has 2813603
Old Aug 4, 2013 | 12:59 PM
tony_2018's Avatar
Fish Twig
You aren't being specific about the check engine code but I'm sure I know what it is.
You didn't wire in the vtec oil pressure switch thats why you have the check engine light. JDM motors don't have vtec oil pressure sensor so you need to wire it in along with the vtec wire. Yes the motor won't run the actual vtec, it does have regular vtec at around 5k, but with the hx p2m ecu you should be fine as long as you don't go past 5k.
Old Aug 4, 2013 | 03:43 PM
CrackerJDM's Avatar
Sorry, CEL code is P1259 for manufacter code
Old Aug 4, 2013 | 03:58 PM
jbpnoman's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
jmeyer99
Oct 14, 2010 08:35 AM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
AIWFCIATR
Jul 23, 2004 12:11 AM
b19coupe
Sep 3, 2003 07:02 PM
digitalhav0c
Apr 9, 2002 11:05 AM
