climate speed/fan blower dead?
My blower fan doesn't stopped working and the climate fan speed light is out? Can it be electrical problem or is it just the bulb for the climate control that needs to be replace. And just replacing the blower resistor. Everything worked fine a weeks ago. Still can't figure out the problem. Thanks
the resistor lets you select the speed of the fan. id try the relay and the resistor first. could be a bad blower motor but that should be the last thing you do.
Which or where is the relay. I took the resistor out but forgot to check the voltage of it but it looks fine. I checked the wires for any shorts to the plug into the resistor, and everything seems like it's good. Just trying to figure out my lights behind the speed number and the air cycle or air flow through my car is dead and blower isn't working. I'll double check for voltage tomorrow. Any other suggestions will truly help. Thanks
rechecked wires, no shortage in any that goes into the climate control. here's a picture of what i'm talking about. i already checked the bulbs behind and they're fine. anyone who knows why or what can cause the shortage, help would be appreciated. thanks
stageup
13
Sep 7, 2005 10:08 AM
sik_sol
11
Aug 16, 2005 07:16 AM
