help with rpm problem
hi guys i have a d14a3 ej9 i remove the throttle gasket now is with 90hp but my head of the engine told me is from a 1.6 integra zc ..the cars rpm gos to redline only with 1 2 3 gear in straight with 4 and 5 gear it dosent pass 4rpm ..any suggestion and in a hill way it dosent go more than 80km with 3 gear and the rpm stays at 3.5 to 4 rpm ..do i need to program the ecu ? everything in the car is stock.
What....all I was able to make out of that is you can redline the car in 1,2,3 but not 4th an 5th and that your car doesn't want to accelerate in 3the up a hill ?. I see NOTHING wrong here no you don't need to program the ECU and why did you remove the throttle body gasket ?
it's a stock 1.4l what are you expecting from it....
evreywhere my engine is d14a3 75hp is also a d14a4 90hp the engine are the same only in some european country The D14A3 is for tax and insurance reasonce limited to 75hp. The limiter is only a simple metal gasket with a 27mm diameter placed in the inlet flow at the throttlebody.
So you have a d-14 with a Zc head and you changed the throttle body from 27 mm to I'm guessing 54 or whatever the tb size is? Yes you will probably need to tune it and you should get the throttle body gasket for the 90hp engine. Don't just run it with no gasket.
and i have a remus exhaust till 4rpm sound normal but from that point the sound change and stay the same till 7rpm ... and is ridiculous with 90hp top speed 160km are cars with 70hp and dose better than this
i have bought the gasket ..if i put a ecu from a d14a4 or i need to tuned
AddiXz
Apr 16, 2013 06:29 PM
civicH22TypeS
15
Jan 10, 2008 09:33 AM
. removing a gasket does not give you an extra 15hp!!! where did you hear that not even my tuner 2 cams in my GS-R did that.
